Difference between 200WV & 200v rated cap
  • sparkyuiop
    • May 2008
    • 8
    Hi, I need to replace 2 caps in a 750Watt PSU.
    The knackard caps are 1000uf 200wv 105c. All I have close are 1000uf 200v 85c.
    First I can't find out what the difference between 200wv and 200v is?
    Second my replacement caps are thinner than the originals.
    Can someone please advise?
    Regards
    Phill.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Difference between 200WV & 200v rated cap
    WV just means Working Volts. Same thing as regular volts.
    • seanc
      • Nov 2008
      • 1319
      Yep - WV is working volts. Threw me the first time I saw them in an LG Plasma.
      • sparkyuiop
        • May 2008
        • 8
        Hmmm, thanks for clearing that up chaps. I wonder if there are any volts that don't work!
        • delaware74b
          • Apr 2009
          • 628
          The only volts you need to worry about is where your cap volts are less than the circuit voltage. Guaranteed to let out magical smoke (sooner than later)
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • lti
            • May 2011
            • 2551
            I had a set of computer speakers that had a 10V cap filtering the 12V power supply. It didn't blow up, and there wasn't any power supply noise on the output of the amp. The speakers were 12 years old and still had the original caps. That was an unusually good cap.
              master hoarder
              • May 2008
              • 12175
              If I remember correctly, some (if not most?) cap manufacturers actually make their caps withstand a slightly higher voltage than the printed maximum voltage on the cap (if you look at a data sheet for United Chemicon, for example, they will list a surge voltage rating under the WV).
              • Perry Babin
                Operating caps well below rated voltage
                by Perry Babin
                I think this has been answered but I couldn't find the thread.
                Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                Or would it require reforming?
                05-23-2024, 05:43 PM
              • Phil289
                Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
                by Phil289
                Hi
                Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
                Is there any reasons why they shouldn't be used?
                I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
                If I can't find any Panasonic what would be any other good makes to consider?
                Thanks 🙂
                09-25-2022, 03:02 PM
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
                KDMPower MIPC MI-X8775CD [PCB WF-C rev:E]
                by momaka
                Remember that cheap $15 PSU that dmill89 posted a while back here?
                https://www.badcaps.net/forum/showthread.php?t=72229
                So I was randomly browsing on eBay (as always) and saw a listing for supposedly the same “775 Watt” PSU with starting bid at $1. Description stated “for part or repair”, with the owner/seller mentioning the PSU had blown/shorted. Surely I could spend a few $$ more and get the same PSU as dmill89 right from Amazon brand new and (probably) working… but where is the fun in that?!
                So I got this one instead...
                11-17-2020, 12:03 AM
              • angelos
                Hisense LCD42W60P Television
                by angelos
                Hi Guys,
                I have this 2008 lcd tv that uses ccfl lamps. The tv is stuck on standby. This is what I have noticed. The standby 5Vs voltage is not 5V but rather 3.28V. There is a 14V rail as well but that measures ok. I put my volt meter on the 5Vs rail and switch on the 220Vac. I noticed that the 5Vs rail goes to 5.1V and quicky changes to 3 28V and steady.
                I unplugged the main board and ccfl lamp wires and tested the power supply separate from the tv without load and put a 470 ohm resistor to the stby rail to force the tv on.
                1. Pfc circuit activates and mains smoothing cap is...
                07-12-2025, 11:44 AM
