Did my first PSU recaps
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Finally got around to doing the two Startech PSUs that I have here that had bad caps. The ATXPOWER300 had 4 dead Fulltec 2200uf 10v caps, and the ATXPOWER250 had 1 dead SC (or CS?) 2200uf 10v cap. Both recaps went fine and everything works great. Here's the pics of the dead caps:
    Ludicrous gibs!
  • Newbie2
    • Sep 2005
    • 885
    Re: Did my first PSU recaps
    Will you post the pictures of the internals of your two StarTech power supplies with the new caps?
    What brand of cap did you use for the recapping?
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I used Rubycons for the recap. The internals look the same as what's in the Power Supply Build Quality Pictorial thread, except now they have rubycons, so purple.
      Ludicrous gibs!
      • yanz
        • Nov 2004
        • 910
        so you use rubycon mbz?
        do you just recap it or desoldered the wire first?
        days are so short when you actually do something..
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          For those PSUs I used the Rubycon MBZ series that I purchased from Topcat. I think for my next one I'm going to be trying some Samxon caps for a change. The Ruby's are nice, but pretty expensive.
          I just recapped it like I would a motherboard. There was enough room around everything to get the caps out without having to remove anything else. I just unscrewed the board from the chassis, and there was enough slack on the incoming wires to twist the board out of the chassis and do the work. I can see where some PSUs would be damn near impossible, with as tightly packed as they are, but these were relatively easy...
          My next recap is going to be a Topower server supply with 3 dead caps. I just need to get the values of the current caps and decide what I want to use in it's place. It's a beast... the pics of it will be up tomorrow sometime.
          Ludicrous gibs!
          • double_DD
            How can I be sure that my EC chip is dead?
            by double_DD
            As the title suggests, how can I be sure that my EC chip is really dead?
            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
            03-12-2025, 07:47 AM
          • disorder
            ps5 edm-033 dead after hdmi/usb ports destroyed
            by disorder
            hello guys,
            i need help to repair a edm-033 ps2
            history : as always hdmi port and usb ports destroyed after unplugged
            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
            so i changed it
            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
            i don't see any projection of liquid metal on pcb.
            01-14-2025, 12:48 PM
          • zunasthegreat
            Chieftec GPS-450-AA with dead 20N60C3
            by zunasthegreat
            Hello everyone hope all doing well!
            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
            09-01-2024, 07:12 PM
          • Beton
            Finding a dead short component
            by Beton
            Hi guys!
            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
            I have a bench PSU and if I try to inject voltage the voltage...
            12-10-2021, 01:05 PM
          • FiguringITout
            MSI Raider GE75 - Not posting, probable dead CPU
            by FiguringITout
            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
            07-25-2024, 07:27 AM
