The Mega SMPS Design Cheat Sheet!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    To stop bumping that old thread, and because i have made significant improvements to the spreadsheet, i decided to post it in a new one.
    I have added half bridge and full bridge calculations. And there's LOTS more goodies to come, i'm just getting started. What i promise you is that there will be MORE variables, like voltage drops of transistors and diodes, to provide the best possible accuracy. And there's more... but i'll keep it a surprise for the time being.
    There will also be more tips on snubbers and voltage spike elimination devices, as once you have a working supply, lowering its noise level is the next challenge. I'm also working on a fresh-out-the-oven low power split supply of my own design for use in standby/driver circuits for half- and full bridge supplies. Say no to flimsy and expensive IC drivers - with a bipolar driver supply, a small and easy to make gate drive transformer is all you need to drive ANY configuration of switching devices.
    And beyond this, i also have real life and school to attend to... I'm a busy guy.
    PS. You know, it occured to me that there's no "SMPS for Dummies" book. I might just write one someday.
    A working TV? How boring!
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: The Mega SMPS Design Cheat Sheet!
    http://www.amazon.com/exec/obidos/AS...00/hsecrets-20
    I heard that is supposed to be a pretty good book as far as a "SMPS for dummies" type thing.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Preachin' to the choir... I have it already. I even recommended it in the readme section of the spreadsheet that you didn't bother to read. It's comprehensive but it's got too much math for a dummy to understand... and some of the results of the equations are pulled out of the blue with no explanation on how he got there. It's a good book (especially the chapter on control loop compensation), but there are easier ones.
      Edit: Uh, one little thing i haven't mentioned. For bridge topologies the value you get is the total number of secondary turns including the center tap. That means, you wind half the number you get in the spreadsheet, pull out the center tap, then wind the other half in the same direction.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Updated.
        • Fixed half and full bridge inductor size (it came up as double what it should be, bridge topologies use full wave rectifying so ripple frequency is effectively double the switching freq)
        • Adjusted a constant in the inductor equation
        Happy building.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Stay tuned, even more goodies coming up.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Annnnddd... Updated! Check out the awesome new compensation components calculator. Enjoy. I did the math so YOU don't have to.
            • Rulycat
              • Apr 2010
              • 724
              This could be very handy, thankyou.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Updated.
                • Fixed a real big oopsie in the primary cap ripple calculator
                • Ripple voltage is now shown as RMS
                • Added calculations for 60Hz mains
                • Other minor additions
                Enjoy.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Added Push-Pull converter.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    Updated. I'm surprised noone caught this till now - the inductor values calculated were wrong (too large). It's not that the power supply wouldn't work with such a large inductor, but it needs more wire, makes compensation a tad more difficult, and increases the voltage spike when suddenly disconnecting a big load.
                    I apologize for the error, all's good now.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Definitely going to download that excel spreadsheet. So if you can find that book cheap, is it worth getting?
                      • Rulycat
                        • Apr 2010
                        • 724
                        I've got the second edition (released 2012) and it's excellent. My brain has exploded though. I suspect it will need many passes reading it as well as experimental testing to understand even half of it. The bits that throw me the most are the equations requiring partial differentiation. Agh!
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Sweet, I'll probably get it so my brain can explode as well. In a good way, not a HKFA PSU way
                          • madan1
                            Troubleshooting half-bridge smps
                            by madan1
                            Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
                            The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
                            Both mosfets were tested outside circuit with a component tester and seem to be fine.
                            With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
                            So I guess the mosfet driver is faulty?
                            01-23-2025, 06:05 AM
                          • dkneyle
                            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                            by dkneyle
                            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                            02-01-2022, 02:08 AM
                          • shamsudeen
                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                            by shamsudeen
                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                            07-19-2025, 07:14 AM
                          • Roman555
                            Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
                            by Roman555
                            Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
                            • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
                            • USB stick with MS-DOS can be loaded via F8 boot menu;
                            • Other OSes won't load - hangs or goes reboot;
                            • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
                            • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
                            What I've already done and it hasn't helped:
                            • Cleared CMOS many times;
                            • Flashed different versions of BIOS in a CH341 programmer;
                            • Updated
                            01-18-2024, 06:26 AM
                          • Byte_76
                            Gainward GTX 295 SLI Bridge
                            by Byte_76
                            I have a Gainward GTX 295 with two PCB's which has a broken SLI bridge ribbon cable. As a result, the card is entirely useless and I'd really like to fix it if possible.
                            I've searched eBay and AlieExpress but haven't been able to find the part.
                            I believe this same SLI bridge cable is used on the Nvidia 9800 GX2 and the GTX 295 which both have two PCB's.
                            Can anyone help me on where to get a replacement SLI bridge cable please?
                            05-10-2024, 03:07 AM
