Suspect Bad PS Apple AcBel API 1PC36
  • Toasty
    • Jul 2007
    • 4171
    #121
    Re: Suspect Bad PS Apple AcBel API 1PC36
    Seriously doubt it's C30.
    veritas odium parit
    • thestitch
      • Sep 2011
      • 3
      Hi, Toasty !
      After several days of severe testing the PSU under very
      nasty thermal condition... yes, it`s rock stable again ! ! !
      Put 4 (!) 15k SCSI HDs in and connected an 22" ADC Display to ATI 9800,
      after appx. 90 starts no PSU failure :-)
      Faulty cap was C30 in this PSU.
      willy
      • Chevy2
        • Apr 2012
        • 73
        I have the same PSU, same symptoms, but the white 25V lead is shorted. Any ideas what I should check?
        • Toasty
          • Jul 2007
          • 4171
          #124
          Regulator.
          veritas odium parit
          • Chevy2
            • Apr 2012
            • 73
            Sorry, it's been a while since I've done any electronic components repair (other than just replacing bad caps). Do you know which one I should try to replace first or the quick process to track down the bad one? Thanks.
            • Toasty
              • Jul 2007
              • 4171
              #126
              You are stating that the 25v line is shorted. What makes you say that?
              veritas odium parit
              • Chevy2
                • Apr 2012
                • 73
                Looks like the 25v was me and some bad soldering. That part is fixed now. I get 5v trickle and 25 volts, but no trickle 12 v like I should per the link below. I have one 2200uf that looks fine, that I haven't replaced yet, should I go ahead and change it out too? The PSU fans spin and turn off when I push the power button.
                http://www.jcsenterprises.com/Japama...EB2C04619.html
                • Toasty
                  • Jul 2007
                  • 4171
                  #128
                  Best read that pinout again.
                  veritas odium parit
                  • Chevy2
                    • Apr 2012
                    • 73
                    Looked it over again. They made it sound like the 12v was a trickle. Since the PSU fans spin up and quickly turn off when pushing the power button (motherboard lights up too) and I have 25v and 5v trickles, which caps would you recommend replacing next?
                    The motherboard boots fine btw. I tested with a PC supply and an adaptor that I made.
                    • Toasty
                      • Jul 2007
                      • 4171
                      #130
                      See Posts #11 & 119.
                      veritas odium parit
                      • Chevy2
                        • Apr 2012
                        • 73
                        Thanks Toasty...appreciate the help!
                        • Chevy2
                          • Apr 2012
                          • 73
                          Toasty, thanks for taking the time to help me out. C43 and the secondaries were the issue and it's working perfectly now.
                          • Toasty
                            • Jul 2007
                            • 4171
                            #133
                            Great! Was just going to ask how you made out. Glad you got it working!
                            veritas odium parit
                            • stevenA
                              • Oct 2012
                              • 19
                              • france
                              #134
                              Thanks to all of your posts (especially Toasty and his lessons) I have just recapped a G4 MDD PS and solved the long running problem that it would only start with an ADC display connected.
                              For info, the bad caps were:
                              C16
                              C21
                              C29
                              C43
                              C60
                              C32
                              C45
                              and maybe C30 which was out of limits for my tester.
                              Said otherwise, all of the Teapo's removed had failed, and some of the L-Tec's. I suspect that the start up problem was linked to C32 or C45, although this is only a suspicion - either way, they all needed replacing as smoothing caps can cause bigger issues in the long term!
                              Thanks again
                              • stevenA
                                • Oct 2012
                                • 19
                                • france
                                #135
                                C16
                                C21
                                C29
                                C43
                                C60
                                C32
                                C45
                                Thanks again
                                After finishing the job and testing, I QC'd the components used and recorded actual results - as you will see in the attached, I actually used the wrong component for C35 - I had intended to use a UCC KY but had multiple caps and made the mistake. Hopefully should not be critical as this is a smoothing cap
                                • frantal
                                  • Jan 2017
                                  • 5
                                  • Italia
                                  #136
                                  Hi, my G4 MDD (dual 1,25) did not turn on, nor the power button on the monitor ADC. So I recapped on the PSU C43 (100uF/25) and C60 (1000uF/10). Now the light on power button of ADC monitor turn on, but no chime and no life signs on the computer. Besides this it is very difficult to know where the critical caps are located. I bought all the caps in the list "MDD PS Replacement Caps as Used 20th Oct-2.pdf", but until now only 2 substituted. Could you suggest me where to find the critical on the list, if you have just done this work? I attached label type of PSU and the side where I think there are the "critical" caps. Many thanks for the help...
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #137
                                    Here is my drawing from several years ago. Hope it helps!
                                    T
                                    veritas odium parit
                                    • frantal
                                      • Jan 2017
                                      • 5
                                      • Italia
                                      #138
                                      many thanks!! I will go to do this work....
                                      • frantal
                                        • Jan 2017
                                        • 5
                                        • Italia
                                        #139
                                        Many thanks for the drawings. It made me the work shorter! Now all works again!! I checked with ESR/Capacity meter and only 2 caps gave me bad measures, the small ones (0,47uF and 47 uF. The other seemed still good. In any case now PSU is renewed!!
                                        • Kansas Sparks
                                          • Jun 2017
                                          • 9
                                          Finally, the correct thread... Thanks again Toasty! Much higher resolution file is available if you'd like. Just email me. I'll most likely be in touch again, once I crack open a Samsung PSU for clarifications on a similar line-art project. Cheers!
                                          • jetblue
                                            need help with Apple AcBel 1PC36
                                            by jetblue
                                            hi,i recently recapped a non responsive acbel 1pc36 power supply. i need to know what is the plugged in state for this supply with no jumper wire on the on plug pins.
                                            is it normal for the fans to come on and meter readings on the plug to be normal? or does the start pin need to be bridged to get any readings from the plug?
                                            it seems like its stuck on on and not standby from what i read on the threads.
                                            its not cycloning only when i bridge the other set of pins will it do that but im not sure if its because im not plugging the pins right because after a while it stops....
                                            09-06-2022, 11:51 AM
                                          • a_p3rson
                                            Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                            by a_p3rson
                                            Hi there,
                                            I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                            You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                            This daughterboard uses an interesting...
                                            04-21-2025, 11:41 PM
                                            HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-12-2024, 02:30 PM
                                            HP EliteBook 830 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 830 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Apple AirPods Pro boardview and 830 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 07:50 PM
                                            HP EliteBook 840 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Apple AirPods Pro boardview and 840 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
