EA-500D boots one PC but not the other
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: EA-500D boots one PC but not the other
    EA-500D Green has 22 amps on each +12v rail.
    Radeon HD 4850 TDP is 114 watts and if we assume a mediocre regulator efficiency of 75% that's 152 watts at the PSU.
    If it all pulls off +12v that's 12.7 amps.
    HHD's are roughly 1 amp /@ on +12v and a burner up to about 2 amps so that's another +5 amps.
    Lets say maybe 3 amps for CPU+System fans...
    .... So you're up to around 20.7 amps on the non-CPU +12v rail.
    If you are sporting a RAID card that could be tapping a few more amps and I've seen some newer mobos that power RAM [except in standby] from +12v with a VRM dedicated to RAM.
    If you have all of that on one rail you just might be over the 22 amps, especially while drives are spinning up.
    TDP on a i5-750 is 95 watts so [w/VRM effiecency] it's probably about 127 watts [10.6 amps]
    Try the system with no hard drives connected.
    If PSU stays on, then do some rewiring and move the +12v to the HDDs to the other rail.
    Mann-Made Global Warming.
    - Dr Seuss
    • mockingbird
      • Dec 2008
      • 5484
      That's stretching it, I don't think that's the problem.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Originally posted by Rulycat
        I know older PSUs had some sort of -5V or something that is missing on new PSUs.
        Maybe the board needs that?
        -5v was for the ISA BUS which pretty much went away with ISA slots.
        MSI was using 16-bit chips directly on the mobo through an internal ISA BUS on boards with no ISA slots for a while as a means to 'cost down' their boards but that stopped about the time i845 chipset did the went part of came and went. They used the cheaper 16-bit chips for sound and/or LAN. [That's why some early MSI P4 boards need -5v for full function even though they have no ISA slot.]
        MSI might not be the only one that did that trick but they are the only one I know for sure did.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          No that isn't stretching it at all.
          Only 22 amps with a 'big' video card and a slew of drives is pushing it.
          - Except I got the problem backwards..
          It's the lower powered board the 500-watt won't work with.
          I'm stumped.
          I don't like to be stumped..
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Have you tried the 650w [or some other PSU] on the older board since the time it wouldn't stay running with the 500w - and it ran??
            Maybe in handling you developed a chassis ground somewhere.
            - Dr Seuss
            • mockingbird
              • Dec 2008
              • 5484
              #26
              Like we agreed before, probably some lousy caps inside the Antec. He said he had the new "Green" edition. Last I checked that thing was full of substandard Taiwanese parts.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                That doesn't explain why it works fine on the more power hungry motherboard.
                - Dr Seuss
                • DOS-man
                  • Mar 2011
                  • 16
                  #28
                  Yeah, I have the old setup running off the 650 right now, no problem at all. I've been swapping the 500 and the 650 in and out to test. Also, I pulled out the RAM and vid card. Even powering only the processor and the mobo, it still doesn't work.
                  • mockingbird
                    • Dec 2008
                    • 5484
                    #29
                    Originally posted by PCBONEZ
                    That doesn't explain why it works fine on the more power hungry motherboard..
                    Different motherboards have different initial power draws and the like... It could be that the motherboard where this PSU doesn't work is exploiting some weakness in the PSU caused by the defect which is causing some failsafe mechanism in the PSU to kick in.
                    The only other explanation is some flaw in its design.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      - Dr Seuss
                      • DOS-man
                        • Mar 2011
                        • 16
                        #31
                        I've got a cheap multimeter, anything I could test?
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          This is really an odd problem. Not sure where to start...
                          Perhaps check voltages on both PSU's [on old mobo] while it's trying to boot to see which is different.
                          How [or are] the PSU's mounted when testing the old board?
                          Is it in the case or off to the side?
                          And,, how is the mounting different from new to old system.
                          - I'm looking for grounding issues/situations that are different between the two set-ups.
                          .. Maybe the 500w has [or lacks] an internal ground that interacts with the mounting situation somehow...
                          [I may not have worded that well but I think you'll get it...]
                          - Dr Seuss
                          • DOS-man
                            • Mar 2011
                            • 16
                            #33
                            I've tried it both fully installed (screwed in), and sitting outside the case, it makes no difference. I also pulled the mobo and put it back in, just in case something might have gotten loose or was causing a short or ground I could not see, but that did not change anything either. I'll check the voltages tomorrow and see if I can find anything.
                            • DOS-man
                              • Mar 2011
                              • 16
                              #34
                              Well, I tried getting voltage measurements, but it shuts down so quickly that it's very difficult. I think I'm just going to use the 650 with this mobo going forward. Even if I can figure out why this is happening, I don't see how that leads to a solution.
                              Hate to throw in the towel, but since I've got a working solution, I think I'll call it good. May revisit it later if I feel like it. Thank you for taking the time to assist me with this.
                              • N3Star
                                ASRock X99 Extreme4 boots only on cold boot
                                by N3Star
                                The motherboard in question boots only on cold boot - if I cut power to the PSU it will boot fine, but as soon as I reboot from Windows or even short reset pins it goes into bootloop - 1 second on, a few off and so on.
                                Initially the board arrived to me broken - bad PCH, after replacing it it worked for a while. I suspected a bad connection, but pushing the IC down does nothing. I don't really think that the PCH is dead, since it still boots and works fine until I reboot the PC. Obviously I tried looking for something that heats up or bad caps, but nothing so far....
                                Yesterday, 02:53 PM
                              • pepebmx
                                ThinkPad T14 Gen 3 - Boots Only on Charger
                                by pepebmx
                                Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                                Laptop: Lenovo ThinkPad T14 Gen 3
                                Serial No: PF-437QTG
                                PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                                Extracted BIOS: Will upload tomorrow
                                BIOS Password: None Issue Description:
                                • Boots only on charger → Works normally when connected to AC.
                                • With battery connected:
                                  • Fan spins at full speed, no display.
                                  • Not all voltages present (some missing).
                                • Battery charges correctly (detected in Windows, shows percentage).
                                • When battery is plugged in while in Windows:
                                  • Laptop shuts
                                05-08-2025, 01:53 PM
                              • abajor
                                A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                by abajor
                                Having this very weird issue.
                                The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                I swapped with a working screen from an A2141 waiting for parts.
                                The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                04-27-2024, 01:37 PM
                              • YOUCEF4787
                                Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                by YOUCEF4787
                                I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                Initial Problem:
                                The laptop was completely dead, no signs of life, no power LED.
                                Action Taken:
                                I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                Current Situation & The Main Issue:
                                The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                09-21-2025, 12:19 PM
                              • reformatt
                                Macbook M2 A2338 locks up after logging in
                                by reformatt
                                This machine will boot to the login page fine. But once you login, the progress bar gets about 10% of the way across, stalls for around 1 minute or so, then the MAC reboots back to the login page. This machine had FileVault disk encryption enabled and appeared to be running Monterey.
                                Board looked clean, apart from a corroded cap near the WIFI IC (which was partially shorted). Fixed that but fault remained. It boots to recovery mode, you can run disk checks etc. But that also locks up after around 5 minutes. Pretty sure this was a bad touchbar, but didn't have one to hand. These are...
                                09-02-2024, 08:13 PM
