EA-500D boots one PC but not the other
  • DOS-man
    • Mar 2011
    • 16
    Hello, and thank you for your help.
    I have an Antec Earthwatts EA-500D that I recently tried swapping from my newer PC into an older one. However, I find that though it worked normally in the new PC, it will run for only 1 to 2 seconds in the old PC before it shuts down. The old PC works normally if I use my EA-650 PSU, but I'd rather use the EA-500D because I find it to be quieter overall.
    New PC.
    i5-750, Gigabyte P55-ud3R, XFX Radeon 4850, 8GB DDR3, 3 Hard drives, 1 DVD-RW.
    Old PC
    AMD Athlon II 4200+, Abit KN8-SLI, Gigabyte 4550 (No external power connector), 4GB DDR, 1 hard drive, 1 DVD-ROM.
    Troubleshooting I've tried.
    1. Swapped 12v connectors on the motherboard - no difference
    2. This board (KN8-SLI) as an unusual molex connector at the bottom that is apparently included for sending extra power to the PCI-E slots. I tried plugging that in, it made no difference.
    3. The motherboard can also apparently run on either a 24 or 20 pin connector, so I tried running it either way, but nothing changed.
    At this point I'm guessing this has something to do with power draw on either the 12v or 5v lines, but the load table on both PSUs is pretty close. The EA-500D provides 24A on the 5v, the EA-650 provides 25A. This difference seems too insignificant to make a difference, but I can't figure out what else it could be.
    Anyway, really scratching my head over this, thanks for your help.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: EA-500D boots one PC but not the other
    EA-500D has two +12v rails
    EA-650 has three +12v rails
    Sounds like you are loading a +12v rail too heavy.
    Try evening out the +12v load across the rails.
    Mann-Made Global Warming.
    - Dr Seuss
    • DOS-man
      • Mar 2011
      • 16
      Thank you for replying,
      I did some further testing, and it still does this if the only things it's powering are the CPU, mobo, and RAM. I even pulled the video card, but that didn't change anything.
      • mockingbird
        • Dec 2008
        • 5484
        Maybe some of the capacitors inside died. IIRC, there were some questionable caps in my EA-500D last time I opened it up.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Every Earthwatts I've seen has some questionable caps.
          Usually have some LTEC and/or Taicon.
          But so far I haven't seen [or heard of] one going bad over caps problems.
          Was doing preemptive recaps for a while but now I'm using them as-is to see if they last like that.
          - Dr Seuss
          • seanc
            • Nov 2008
            • 1319
            Hmm, this would be the first Delta built Antec *I've* seen with an issue, although I think I have one at the office is which is squealing.
            Pics of the inside please.
            • DOS-man
              • Mar 2011
              • 16
              Thanks for all the replies.
              Because this unit is still very new, and I'm still just learning about PSU repair, I've decided to RMA the unit. I know it goes against the spirit of this board, but I've got to be realistic about my chances of executing a repair successfully, and I'd rather not learn to solder on something that's still under warranty if I have other options. I will post a followup when I get the replacement. I still have a feeling that maybe this board and this PSU just don't get along for some obscure reason.
              Again, thank you.
              • mockingbird
                • Dec 2008
                • 5484
                I heard that there are two revisionjs of the EA-500D. If your unit is new, I would be curious to see their new design, though you shouldn't open if it's still under warranty, and you did good by RMAing it. Why should you bother with it if it's under warranty?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  That I know of: EA-500, EA-500D, EA-500D-Green
                  - Dr Seuss
                  • DOS-man
                    • Mar 2011
                    • 16
                    The PSU in question is the EA-500D Green
                    • delaware74b
                      • Apr 2009
                      • 628
                      ^x2 - warranty replace the power supply unless you've opened it. It has a 3-year warranty.
                      Stupidity should be a crime, especially for drivers. I have NO patience for them.
                      • DOS-man
                        • Mar 2011
                        • 16
                        Ok, so replacement arrived today. Plugged it into the motherboard, powering no other components, and... Same exact problem. The problem must be in the interaction between the board and the PSU. What could it be?
                        • Rulycat
                          • Apr 2010
                          • 724
                          I know older PSUs had some sort of -5V or something that is missing on new PSUs.
                          Maybe the board needs that?
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Any burned looking pins in the connectors?
                            - Dr Seuss
                            • DOS-man
                              • Mar 2011
                              • 16
                              Nope, connectors look fine. Also, this board boots OK with my EA-650 v2, reviewed here. http://www.jonnyguru.com/modules.php...Story&reid=110
                              In notice that the EA-650 supplies 25 amps on the 5v and 3.5v rails, but the EA-500D Green supplies just 24 amps on those rails. That seems like too small a difference to be the source of the problem, but could that be it?
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                I was talking about the motherboard side too...
                                I know what they look like, I have 2 or 3 of them..
                                And a review won't tell me if YOUR pins are burned or not..
                                No.
                                - Dr Seuss
                                • DOS-man
                                  • Mar 2011
                                  • 16
                                  I should have indicated that I was referring to the connectors on the motherboard. I gave them another close examination just now and they look as good as new, no scorching or discoloration.
                                  Good to know that I was correct about that amperage difference. Thank you for taking the time to reply.
                                  • Rulycat
                                    • Apr 2010
                                    • 724
                                    Very odd situation.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      You did check the 2x2 [4-pin] also. The whole reason I asked is that someone was using mis-sized parts for a while. The pins in the 2x2 on mobo didn't get good contact causing them to burn. Unfortunatly I can remember exactly who had that problem.
                                      - Dr Seuss
                                      • DOS-man
                                        • Mar 2011
                                        • 16
                                        Indeed, checked those as well. No problem there either.
                                        • pepebmx
                                          ThinkPad T14 Gen 3 - Boots Only on Charger
                                          by pepebmx
                                          Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                                          Laptop: Lenovo ThinkPad T14 Gen 3
                                          Serial No: PF-437QTG
                                          PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                                          Extracted BIOS: Will upload tomorrow
                                          BIOS Password: None Issue Description:
                                          • Boots only on charger → Works normally when connected to AC.
                                          • With battery connected:
                                            • Fan spins at full speed, no display.
                                            • Not all voltages present (some missing).
                                          • Battery charges correctly (detected in Windows, shows percentage).
                                          • When battery is plugged in while in Windows:
                                            • Laptop shuts
                                          05-08-2025, 01:53 PM
                                        • abajor
                                          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                          by abajor
                                          Having this very weird issue.
                                          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                          I swapped with a working screen from an A2141 waiting for parts.
                                          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                          04-27-2024, 01:37 PM
                                        • YOUCEF4787
                                          Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                          by YOUCEF4787
                                          I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                          Initial Problem:
                                          The laptop was completely dead, no signs of life, no power LED.
                                          Action Taken:
                                          I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                          Current Situation & The Main Issue:
                                          The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                          Yesterday, 12:19 PM
                                        • reformatt
                                          Macbook M2 A2338 locks up after logging in
                                          by reformatt
                                          This machine will boot to the login page fine. But once you login, the progress bar gets about 10% of the way across, stalls for around 1 minute or so, then the MAC reboots back to the login page. This machine had FileVault disk encryption enabled and appeared to be running Monterey.
                                          Board looked clean, apart from a corroded cap near the WIFI IC (which was partially shorted). Fixed that but fault remained. It boots to recovery mode, you can run disk checks etc. But that also locks up after around 5 minutes. Pretty sure this was a bad touchbar, but didn't have one to hand. These are...
                                          09-02-2024, 08:13 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
