Macbook M2 A2338 locks up after logging in
  • reformatt
    • Feb 2020
    • 1470
    This machine will boot to the login page fine. But once you login, the progress bar gets about 10% of the way across, stalls for around 1 minute or so, then the MAC reboots back to the login page. This machine had FileVault disk encryption enabled and appeared to be running Monterey.
    Board looked clean, apart from a corroded cap near the WIFI IC (which was partially shorted). Fixed that but fault remained. It boots to recovery mode, you can run disk checks etc. But that also locks up after around 5 minutes. Pretty sure this was a bad touchbar, but didn't have one to hand. These are bloody expensive for this model...like 3 times the price of the older models!
    Cut a long story short, I had a spare A2338 machine in for repair for other issues, so swapped the board into that chassis. Boots fine. But I've had bad touchbars before but they haven't prevented the MAC booting up, just issues with coming out of sleep.
    The difference here was FileVault. I turned this off in the donor chassis, and when I reinstalled the board to the original chassis, it logged in fine, albeit with a dead touchbar. I'm assuming that this thing will have issues with coming out of sleep until I get the replacement touchbar. Machine was indeed running Monterey.
    On an unencrypted device, the Touchbar should light up at the login page. However it does not do this at all on an encrypted device as MAC OS has not yet loaded. So it is hard to know that the touchbar is indeed faulty other than trying another or swapping it to another chassis. I don't know if this is an issue on later versions of MAC OS. I'm unclear as to why MAC OS boots fine with a dead touchbar, but crashes when you have FileVault turned on. It would seem to me that FileVault is completely superfluous now since the SSD on these is encrypted anyway by the controller. There is no point to it really.
    Anyway, it's a strange enough issue to post it here.
  • jkruns
    M1 A2338 screen and touchbar issues after cleaning up liquid damage
    by jkruns
    This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
    My patient is an A2338 Macbook Pro M1 (late 2020).
    It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
    04-22-2024, 06:45 AM
  • Jamo33lovelock
    820-01814-A Touchbar not functioning
    by Jamo33lovelock
    This is my first post asking for help, but I feel I have now reached a point where I am out of my depth entirely.
    820-01814-A board model, purchased with knowledge it was faulty and had water damage that had affected the touchbar. Water damage was located around the touchbar connectors to the point there were open circuits. When turned on the touchbar would light up, but the entirety of it was scrambled colours and pixelation.
    I replaced the topcase (wasn't comfortable doing a touchbar swap) expecting this to be a simple issue of an open circuit, but...
    09-06-2022, 04:12 PM
  • todordm
    Macbook A2338 / A2337 - Replace SSD
    by todordm
    There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
    01-17-2024, 03:55 AM
  • modtool
    Macbook Pro A1989 fallen, reboots if touchbar connected
    by modtool
    Hi to all,
    the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
    Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
    11-10-2023, 07:42 AM
  • User555111
    A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
    by User555111
    Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
    02-05-2024, 08:16 AM
