A simply Question about SG6840 PWM Controller, must the VDD Voltage on Pin 7 measurable after PWM starts or also before and even if the PWM is defective ?
Its an external TFT SMPS with no power failure(no secondary output), i checked all the parts and replace some caps and also the MOSFET, but i cant find the failure, bridge rectifier and cap is working normal, on the middle Mosfet Pin is 320V, on the PWM Vin Pin is 5V, but on Pin 7 VDD i read only 1.7V, (with black probe on Hot Ground) should be about 16V ?, where comes the VDD Voltage normaly, from the bridge recifier, or only from the MOSFET after the PWM starts ?
Sorry if that is an stupid Questions, i´m not an expert in such things.
All smd resistors are ok, also the 10uF/50V Cap(replaced by new one), Z-Diode include.
Thanks,
Thomas
Thanks,
Thomas
