Cracking open wall warts, how do YOU do it?
  • smason
    • 1652
    I have about 5 wall warts to repair. 4 just have frayed wires at the wall end, so I just need to chop an inch off and re-solder. These are from Dlink switches that our field staff take out to client sites, and they wrap em too tight when they return them.
    The fifth is a switching 5v adapter from a Netgear router. Probably a bad cap (it's 5v with no load, down to 3.2 when the router is plugged in) but it really doesn't want to open for me.
    I've tried various techniques over the years, freezing, and spacking with a hammer, heating and prying, squeezing in a vise (not a good idea) and good old exacto knife.
    Does anyone have any tried and true methods?
    And what about re-assembly. Epoxy is good, but you'll have trouble opening it again. Hot glue is a bit weak...
  • digge
    • Apr 2006
    • 296
    Re: Cracking open wall warts, how do YOU do it?
    Only other way apart from what you mention that i can think of atm is cutting it open with a dremel with one of thoose circular flat bits in it. If one knew exactly what kind of compound hold them together there might be a solvant that could dissolve it, however it would probably melt on the plastic as well so maybe not viable solution.
    As to holding it together someone else on the forum wrote about just putting cable ties to hold them together. If they are going back out to customers that might not look very good though so maybe glue them back together?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      I use a flathead screwdriver and a hammer... Leaves only one mark, one hit is enough to crack most of the glue on that side, then i simply pull it apart with my hands. I use super glue to put it back together.
      A working TV? How boring!
      • Scenic
        o.O
        • Sep 2007
        • 2640
        dremel with a thin cutting wheel on lowest speed.
        superglue or "liquid plastic" to put it back together.
        (liquid plastic is some gooey black stuff that bonds with the plastic and hardens up after a few hours. sort of like the glue stuff to fix bycicle tires, just for plastic. if done right, you wouldn't notice it at all and it's probably stronger than the original ever was..)
        • severach
          • Aug 2007
          • 1055
          Wall warts are only seen once before they are placed into the wall. Only the most sensitive people will notice a black zip tie around a black transformer.
          sig files are for morons
          • turbozutek
            • Jan 2009
            • 71
            Sometimes they are ultrasonically welded together and in those cases a good hit with a hammer on the join lines will crack it apart.
            • Krankshaft
              • Jan 2007
              • 2328
              Get a block plane blade refill from the big box store place the blade between the two case halves and whack the end of the blade with a hammer. The blade is made of thick steel so it can take a beating.
              The blade acts as a wedge to pry the halves apart most supply manufacturers cheap out on the adhesive so it comes apart easily. Others take a bit more hammering.
              Any marring is minimal thanks to the blades thin profile.
              To put it back together fill the channel with a bead of super glue and hold the case together with two spring clamps until it dries. As for disassembly in the future don't count on it they weren't designed to be opened to begin with you'd be stretching it to open it up a second time.
              This is the only low damage method that I use. Another member once recommended the blade of a cheap knockoff Swiss army knife and hammer on that which would work too.
              • smason
                • 1652
                Thanks all!
                Krankshaft, your method looks really good, will try it.
                • smason
                  • 1652
                  Still haven't found a block plane blade (Home Depot, Lowes, and Canadian Tire don't have 'em) but substituted a chisel, and it worked quite well.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    ebay is an option if you really want one. See
                    http://cgi.ebay.ca/BUCK-BROTHERS-1-9...item5add9d804f
                    --- begin sig file ---
                    --- end sig file ---
                    • japlytic
                      • Oct 2005
                      • 2086
                      Opening an AC adaptor of the switching type is a bit of a hit and miss affair. You either get it open without damaging any components inside or not.
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        I've never damaged any components the heat sinks are usually U and shaped cover the top and come down past the sides which usually protects the internals from any damage during opening at least on the sides.
                        • kc8adu
                          • Nov 2003
                          • 8829
                          • U.S.A!
                          cheap china crap fleamarket grade pocket knife.
                          place its(dull)edge in the seam and smack with hammer.move and repeat.works well for ht batteries too.
                          • Tracy
                            • Mar 2011
                            this is the best and fastest way. take a big square transformer with nice sharp edges, place one side of the wart against the transformer but only the side corner of it, make sure the seam is flat against the sharp edge of the transformer and bang with a rubber mallet, then do the same for the next three corners, works like a charm, no dammage.
                            • TheLaw
                              • Jan 2011
                              • 477
                              Hacksaw or a screw driver + hammer.
                              So far, CapXon has been the filter cap in about 75% of the wall-warts I've taken apart.
                              • mrdevil
                                Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
                                by mrdevil
                                Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
                                However, after about 12 months, I had a number of these stop working...
                                01-08-2025, 03:19 AM
                              • mitsu2k
                                The Real Dangers of conductive glue.
                                by mitsu2k
                                I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                                Here is an experience I...
                                04-16-2023, 06:29 PM
                              • Wes Richards
                                Hard glue/Cracking screen
                                by Wes Richards
                                I have been replacing backlight strips for years now with no problems. Just this month however I have broken 2 screens trying to remove the glue which bonds to the bezel on TCL TVs. I have tried the hair dryer trick and heating up an xacto knife, neither of which worked successfully. Do you have any suggestions? Some techs say use Acitone. Wouldn't that damage the screen? Please help.
                                07-17-2021, 04:18 PM
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                              • Dannyx
                                UC3842 Power Adapter Blowing Fuse
                                by Dannyx
                                Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                12-05-2023, 12:06 PM
