capacitor replace
  • Ximen
    • Dec 2010
    capacitor replace
    Can i replace a 250v 680uf capacitor with a 200v 680uf capacitor..?
    i have a computer power supply with a capacitor of 250v 680uf blew up because i accidentally kept the voltage level low while i turned it on.. so is it possible to replace it with a low voltage and same resistance..
    hope i will get a good answer..
    here is the bad cap n the good one..
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: capacitor replace
    It is possible. I would not recommend it if the power supply in question has active PFC.
    • steve2
      • Dec 2010
      • 121
      I wouldn't. There is probably a little over 200 vdc there and it would either have a very short life or a shortened life. They are rated at maximum working voltage for a reason.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        If there isn't PFC (a big coil near those capacitors), you can safely replace it with a 200v. I've even seen 160vdc caps used in such positions (!!!). The power supply with the 160vdc caps was an AT PSU and worked fine for years till i decided to scavenge it for parts.
        A working TV? How boring!
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          This looks like a low end half-bridge unit. The caps are connected in series for a total of 500V capacity. A bit much considering they usually have ~320V across these caps, so two 200V's should be fine.
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
          • chth96
            Should I replace polymer capacitor?
            by chth96
            a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
            I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
            Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
            Is this ESR value of polymer capacitor correct?...
            11-18-2022, 04:22 AM
          • cap__
            Can I replace 15uf capacitor with 22uf?
            by cap__
            "If I wanted to replace an old 15uF/400V capacitor with a new one,
            I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
            11-29-2023, 11:16 AM
