Power supply build quality pictorial DISCUSSION
This is a sticky topic.
  • yanz
    • Nov 2004
    • 910
    #161
    Re: Power supply build quality pictorial DISCUSSION
    About those Delta PSu we have, anyone have the datasheets for DNA1002 and DNA1001?
    • starfury1
      • May 2006
      • 1256
      #162
      Hi Yanz
      Not that I know of here but PeteS has post a bit of info in these forums
      Link here stating that they are custom made ASIC...(I think it was)
      The DNA1001D being "functionally similar to the UC3854 and UC3842
      combines a PFC controller and a PWM"
      The DNA1002D will most likely contain "error amplifier, opto driver and a bunch of comparators with a reference for fault detection."
      This from my query to him (Thanks Pete)
      He does "NOT" have block or pin out diagram for these chips
      (so please all spare him his pm box )
      His best advice was to contact Delta Electronics and ask support
      (I haven't as yet..yeah I know slacker )
      My searches on the net have proved fruitless Yantz
      (not to say info isn't out there I just haven't found it)
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        #163
        Here was my PM on this topic to Starfury:
        These two ICs are Delta proprietary parts. Unfortunately, I don't have specs or pin-outs. The one on the primary side (1001?) combines a PFC controller and a PWM (functionally similar to the UC3854 and UC3842). If the controller bd. is only half populated, the PFC section is not used. The one on the secondary side contains an error amplifier, opto driver and a bunch of comparators with a reference for fault detection.
        My suggestion would be to send an e-mail to Delta's Sales and Support office, either in the UK or the US which can be found on this webpage. Ask them to e-mail you a pin-out diagram and a block diagram of the two ICs ...
        The specific suggestion of the US or UK offices has to do with Starfury being from the Land of OZ.
        PeteS in CA
        • starfury1
          • May 2006
          • 1256
          #164
          Thanks pete
          Just with that Delta from a quick look today I am suspecting it may be a Mains side problem.
          I would have that that even if shutdown protection circuits were firing to protect it, it should give some glimmer of life...there is none.
          Our mains power here can be at times brutal, its killed a tv or two here.
          Anyway got a cheapie coming to replace it, so it will be a project just to know why it died.
          Its an old HP box I was going to use to play with linux
          • Rainbow
            • Aug 2005
            • 1375
            #165
            Macase 250W ATX - looks like Macron power OEM. They're nice except for the caps sometimes.
            • starfury1
              • May 2006
              • 1256
              #166
              Yeah nice of them to put a line filter IEC connector for mains in.
              As to the Caps they all appear to be the same except possibly for those 2 blue electro's mid section.
              Don't know the brand off hand, but sure someone does here
              Looks like I yank this one none too soon.
              Really must pull the Enermax and check it...been running for about 5 years or more now.
              That box now has the Gigabyte MB in it that I recapped.
              Same deal as willawake's post on GB MB (zx7 or something)
              • MarioMaster
                • Nov 2006
                #167
                hey guys 1st post
                @Power EP-43057 430 watt psu i got from a $20 pc case, i would be scared to load this thing at 200 watts let alone 430 - the wires are thin too
                I'm not sure what brand these caps are, they seem to have some kind of company symbol, but that's it
                AMD Athlon64 3800+ | 1.5gb Patriot PC2 6400 | dual 250 gig WD drives RAID 0 | OCZ Powerstream 520 watt | 7900gt
                • Rainbow
                  • Aug 2005
                  • 1375
                  #168
                  Looks like DEER.
                  • Shroomie
                    • Apr 2006
                    • 356
                    #169
                    UL number traces back to "Power Tech Industrial Co LTD", whoever they are. Same cheap crap as Deer/L&C, anyway.
                    You know there's something wrong when you open up a PSU and are glad to find Teapos.
                    Why I don't buy cheap cases!
                    • yanz
                      • Nov 2004
                      • 910
                      #170
                      starfury1 & Petes, thanks a lot
                      • PeteS in CA
                        • Aug 2005
                        • 3583
                        #171
                        Re that 160W Samsung P/S, the PCB has "Samsung" in the silkscreen, so I'm guessing Samsung actually designed it. The first four characters in the S/N suggest it was built in February, 1998. IIRC, Samsung built late 90s - early 00s iMacs, including the P/S (which, IIRC, was built on the MB).
                        PeteS in CA
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          #172
                          hitachi made that dna chip.
                          case style and lettering give it away.
                          look in old hitachi books for a possible match.
                          • starfury1
                            • May 2006
                            • 1256
                            #173
                            No worries Yanz
                            Found info via google which lead me back here to PeteS reply posted awhile back
                            kc8adu mentioned hitachi (thanks) and that was the only other thing that kept falling out but no pdf's or docs could I find
                            Japlytic has posted some info on pinout (part schematic) of the other chip DNA1002
                            in the orginal post from "larrymoencurly"
                            Delta proprietary chips? What are they?
                            I would like to say a BIG THANK YOU too, to all who help shed a bit more light on these chips
                            Welcome MarioMaster
                            Cheers all
                            • PeteS in CA
                              • Aug 2005
                              • 3583
                              #174
                              Re the Touch SP9627, that is a flyback design, where the "output inductor" is the primary of the transformer. Those little ferrite rod inductors are just for high frequency spike suppression. Clues: low power, single switch device, 400V I/P lytic (probably wide-range I/P voltage or 230VAC only), not active PFC (age and no PFC inductor) and no toroidal or E-core O/P inductor. Probably a UC384X family PWM or maybe a UC290X. The +5V Stby uses a Power Integrations TopSwitch (TOP 220, I think). Looks pretty solid.
                              That "200W" P/S looks scary. Unapproved X- and Y-caps, really skimpy heatsinks, rather small main transformer, primary and secondary wires bundled together using the fan wires, without reinforced insulation. Probably a half-bridge inverter design with a TL494//KA2500B PWM. Probably uses clones of Motorola's MJE13007 or MJE13009 bipolar transistors, with no DC-blocking cap to keep the transformer core from walking into saturation due to slight pulse width variations. The smaller of the two transformers provides base (or gate) drive; no obvious drive transistors, so the internal drive of the PWM is used for that function, which means the base drive is kind of wimpy.
                              PeteS in CA
                              • japlytic
                                • Oct 2005
                                • 2086
                                That "200W" P/S looks scary. Unapproved X- and Y-caps, really skimpy heatsinks, rather small main transformer, primary and secondary wires bundled together using the fan wires, without reinforced insulation. Probably a half-bridge inverter design with a TL494//KA7500 PWM. Probably uses clones of Motorola's MJE13007 or MJE13009 bipolar transistors, with no DC-blocking cap to keep the transformer core from walking into saturation due to slight pulse width variations. The smaller of the two transformers provides base (or gate) drive; no obvious drive transistors, so the internal drive of the PWM is used for that function, which means the base drive is kind of wimpy.
                                The transistors are NEC 2SC2335, and the DC blocking cap (1uF) is a bit hard to see in the photo. There are only 4 transistors; two for the output and the other two for the driver transformer.
                                An output transformer that size would be typical in most supplies that age.
                                The overcurrent detection circuit is similar to modern ATX supplies which use a single transformer for output trasistor drving and current sensing.
                                • Rainbow
                                  • Aug 2005
                                  • 1375
                                  #176
                                  That Kobian is DEER. I have 6 PSUs (and more are coming) branded as "PREMIER LC-B300ATX" which look about the same inside and they all had exactly this problem.
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3583
                                    #177
                                    Re the "Kobian Mercury ATX PSU", what a POS! Wimpy I/P rectifiers, wimpy heatsinks, wimpy transformer - 200W would be scary. WTH is that leaded dual-diode-kludge?! What O/P is it on? I see two TO-220 rectifiers and that kludge ... and the high current O/Ps are 28A (+3.3V), 40A (+5V) and 17A (+12V). Right! Does it toast marshmallows if you try to draw that much current from any of those O/Ps?
                                    PeteS in CA
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      #178
                                      beavis and butthead fire chant in background....
                                      • Super Nade
                                        • Jun 2006
                                        • 294
                                        #179
                                        Yep larry. Antec's SP-400. The outer shell kind of gave it away, but this, probably for the 1000th time, reinforces the fact that Fujjy's are far too unreliable to be recommended.
                                        What do y'all think about the Astec unit?
                                        Q6700 @ 3.6 GHz
                                        Zippy GSM-6600P
                                        Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                                        Abit IP35Pro
                                        ATi HD4870
                                        • Shroomie
                                          • Apr 2006
                                          • 356
                                          #180
                                          Looks like a bigger version of the 200w ones Astec built for Gateway midtowers (late socket 7 and slot 1). They were pretty bulletproof for me - full of Chemicons mainly. The Newtons they used sometimes later on weren't bad either though.
                                          What're the maximum output ratings on that one?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
