Power supply build quality pictorial DISCUSSION
This is a sticky topic.
  • Phaihn
    • Jan 2009
    • 842
    Re: Power supply build quality pictorial DISCUSSION
    ok whats the max power output this thing can handle?
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      We would need internal pics to really determine that. My guess is that it is good for 200W if it is a typical gutless wonder, 250W if it is not too bad on the inside (a decent input filter, not microsized secondary caps, the "35" sized transformer)
      • Phaihn
        • Jan 2009
        • 842
        if i open it that voids the warenty
        My Computer.
        • Phaihn
          • Jan 2009
          • 842
          Cant do much better here sorry.
          My Computer.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Well, its got a non-existent transient filter, but the transformer looks decently sized, and the heatsinks look exactly like a seasonic 300W that I have.
            Those small caps are BH brand, looks like another one of logisys's OEM's.
            • Phaihn
              • Jan 2009
              • 842
              Will splode if i use it?
              My Computer.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                I've seen a logisys 575W run a 8800gts sli'd computer running cod4 on high settings just fine. But the 575W logisys actually has a complete input filter and a bridge rectifier.
                I can't really tell you if it will blow up if you use it without complete inside shots, but if you were to fix it up like I did to my 350W rosewill, then it might do ok for your setup
                • Phaihn
                  • Jan 2009
                  • 842
                  if i open it then i wont be able to take it back and i couldnt find any info online about or on hardwaresecrets.
                  My Computer.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    how much was it?
                    If it was something like $50, I would take it back, as that is wayyyy too much for that. Your old dynex is much better built than it.
                    • Phaihn
                      • Jan 2009
                      • 842
                      49 before GST and PST or HST
                      My Computer.
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3113
                        I don't know. I would return it and get a more reputable brand like corsair, antec, or even fsp. Or you could get the 400W delta that surfaces on ebay for cheap.
                        But it might actually be a decent psu, just we would need internal shots which would ruin your warranty.
                        This 400W delta:
                        http://cgi.ebay.com/New-Gateway-Delt...d=p3286.c0.m14
                        Has a pci-e connector, lots of sata connectors that each have their own little cover, but only a 4 pin cpu connector.
                        There is also a 550W AcBel power supply you can get for about $15, but it dosen't have pci-e. Someone here has a link to the website that you can buy it from.
                        • Phaihn
                          • Jan 2009
                          • 842
                          I over paid for the Dynex too.
                          My Computer.
                          • Oklahoma Wolf
                            • Dec 2005
                            • 353
                            #293
                            Goldenfield's upper end units are CWT. The lower end units like the S628 appear to be Huntkey.
                            This is the 410:
                            http://big5.thethirdmedia.com/g2b.as...3300c26p1.html
                            Huntkey is nearly always overrated by 100W. Some of theirs can be decent. Emphasis on the words "can be."
                            • Newbie2
                              • Sep 2005
                              • 885
                              I guess new PCI-E video cards come with an adapter, so that shouldn't be a big issue.
                              My gaming PC:
                              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                              ASUS M4A77TD AMD 770 AM3 Motherboard
                              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                              ASUS Xonar DG 5.1 Channel PCI sound card
                              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                              Antec Three Hundred Mid-Tower Case
                              Microsoft Windows 10 Pro 64-bit
                              Microsoft Windows 7 Ultimate SP1 64-bit
                              • Phaihn
                                • Jan 2009
                                • 842
                                I dont use PCI e anyway.
                                My Computer.
                                • Newbie2
                                  • Sep 2005
                                  • 885
                                  Is there a warranty sticker stuck between the lid and the main case of the power supply that has to be ripped to remove the lid?
                                  If there isn't, then if you want to take a risk just remove the screws carefully and take off the lid carefully, without damaging the finish on that power supply.
                                  If there is, don't open it.
                                  My gaming PC:
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3113
                                    This is the 410:
                                    So essentially, he probalby just bought another 400W dynex.
                                    • Newbie2
                                      • Sep 2005
                                      • 885
                                      At a slightly better price than the Dynex, along with what appears to be a nice black finish on its case.
                                      My gaming PC:
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #299
                                        Phaihn: just use the Dynex, it's not that bad of a power supply at all. Besides, I don't think your system will go over 200 watts even at full load.
                                        • Phaihn
                                          • Jan 2009
                                          • 842
                                          Theres 2 stickers on it one conectting 2 parts and the QC sticker thats cover one of the screws
                                          My Computer.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
