new/ used psu suggestions
  • PCBONEZ
    replied
    Re: new/ used psu suggestions
    Oh lookie, a Delta DPS-400RB like 370forlife suggested and it's only $30+ship.
    http://cgi.ebay.com/OEM-Gateway-DX44...item3a61af1de7
  • ratdude747
    replied
    ran out of dead psu's with sata
    every sata plu i have seen was built so if there was no 3.3v wire put in orginally, you couldn't. like it was wired then encased in plastic.
    every splitter i have seen was for molex. most were made with thin wire.
    i might have 1 SATA plug left. i can't tell because it is in my junk wire bucket at my old house... if i can rustle up 2 or 3 connectors i might be able to splice the acbel (the sata on the ultra is only 20 gauge for 2 plugs).
  • PCBONEZ
    replied
    #5 in the search at the time I posted this.
    $35+ship, standard ATX, 460 watts and SATA connectors all over it.
    http://cgi.ebay.com/Delta-DPS-460DBB...item4aa732ff52
  • PCBONEZ
    replied
    So you can't solder wires if they are 3.3v?
    You can get the connectors from splitter adapters or dead PSUs.
    It's really just not that hard.
  • ratdude747
    replied
    i know that. but without any SATA plugs to solder, i am out of luck. I can't just snap my fingers and watch one magically appear in my hand. i used to have spares but they got used on things that got traded off, etc.
    my main concern is future compatibility with future drives... the 3.3v line on the sata will be used someday and the adapters will not work. otherwise i would molex adapter it...
  • PCBONEZ
    replied
    Seems to me that anyone that can solder caps should be able to solder a wire.
  • ratdude747
    replied
    cheapest was $40+shipping for a 400w. everything else was either no sata or proprietary mounting.
  • PCBONEZ
    replied
    http://desc.shop.ebay.com/i.html?_nk...eDesc=1&_rdc=1
    Note how search was done.
  • ratdude747
    replied
    i might have something:
    http://www.hypermicro.com/ProductDes...-ML310-&key=it
    i can't tell if it is a 20 or a 20+4 ATX. my research points to 20+4, but i can't tell for sure.
    look like a possible winner?
  • ratdude747
    replied
    the cheapest i could find for anything not A-power trash was $60. for that much, the HEC compucase Zephyr 750W you had for sale was a bargain.
    what scared me was there was more items labeled "4 dell" and was in reality an a-power unit than there were used parts. I wonder how many suckers get screwed by that.
    looks like i will have to see if anybody has an extra unit... too bad i am out of SATA connector or else i would buy the acbel and solder in the plugs.
  • 370forlife
    replied
    Delta dps400rb is always a good choice. Plenty of Newton/Delta/dell 400 to 500w units for cheap on fleabay.
  • ratdude747
    started a topic new/ used psu suggestions
    I am thinking of upgrading the PSU in my main rig.
    Since I might go to sata opticals in addition to the sata hard drives i want to avoid the dorky molex to sata adapters, I want somehting with 4x or more sata plugs
    what I have now is a recapped and de-spliced ultra V 550w. I was going to go for an acbel 550w from hypermicro but again, only 2 sata plugs. my specs are:
    mobo: intel dp35dp
    cpu- PDC 1.8ghz (may someday upgrade to a C2Q)
    graphics- 256mb nvidia geforce 7600GT (may upgrade and need the PCIe connection)
    no OC (my case is not the kind designed for that kind of cooling)
    bling is no concern. Quality is what i want.
    I do not want to spend an awful amount on it... tryign to make my christmas $ do what i want...
    any suggestions for a good psu past or present?
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
    HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
    This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
    09-12-2024, 03:28 PM
  • clabr
    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
    by clabr
    Need help to solve some problems with this laptop.
    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
    Before this had happened I observed some other problems:
    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
    12-02-2021, 08:09 AM
    Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
    by momaka
    Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
    11-28-2020, 11:08 PM
  • playit
    psu sata power wires thinner - does it make a difference ?
    by playit
    hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
    i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
    any explanation on this ?? thank you ,soon i am planning to buy some branded...
    10-12-2023, 05:25 AM
