a sudden rash of fsp,fortron,sparkle,ect psu's with dead fujjyuu(sp)? caps
  • Oklahoma Wolf
    • Dec 2005
    • 353
    Re: a sudden rash of fsp,fortron,sparkle,ect psu's with dead fujjyuu(sp)? caps
    Didn't really consider Nichicon... actually I was going to order extra Panasonic FM's above what I was already getting for my motherboard. Think I should go for the Nichicons instead? Was also thinking of the FM's to replace the Capxon 3900's too. The Fuhjyyu 3300 that's bulging is on the 3.3v rail from what I could see.
    There's plenty of room in there though... the 3300's and 3900's are all 12.5mm wide. The 5v rail is on one of those two oddball 1650uf Fuhjyyus - both need replacing. The caps need to be 10mm wide or I would consider 1800uf replacements, so instead I chose Panasonic FC 1500's. Going Chemicon KY I think for the 1000@16v that is also bulging and leaking.
    • linuxguru
      • Apr 2005
      • 1564
      FMs should be fine - I went with the Nichicons because I located an inexpensive cache with a local supplier.
      Are you sure? They're probably on +12v, one on each leg of the pi-filter, or on the internal supply rail for the controller IC.
      • Oklahoma Wolf
        • Dec 2005
        • 353
        You're probably right - makes more sense to me one of the 3900's nearby, or the other Fuhjyyu 3300 that isn't bulging, is handling the 5v considering the thing is rated for 40A at 5v. It's a little hard to tell with how crammed full that area is. Actually there are 3 16v 1650's total - one's between the heatsinks next to the standby 470uf filter cap, while the other two are on the secondary.
        • Newbie2
          • Sep 2005
          • 885
          Originally posted by Oklahoma Wolf
          I just pulled apart a CWT ATX-375 - the Fuhjyyu 470's in there (all 3 of them) are 8mm diameter. Didn't pay close attention to the length - this one has plenty of room.
          Two need replacing in this unit - it's a friend's PSU, so I'm recapping everything and making a gift out of it.
          The 470uf caps are on Digikey with item number P10274-ND. Panasonic item number EEU-FC1E471L.
          Now back on topic, good luck with the recapping!
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • Oklahoma Wolf
            • Dec 2005
            • 353
            Thanks, though I had the 16v versions already marked for buying I might change them to those 25v versions anyway since I need a lot of them (8 total).
            This is going to be a big job... 3 Channel Well PSU's and an Aopen mainboard. Just hope I can cram the 3300uf 12.5mm diameter Panasonic FM's I picked out into the motherboard's 10mm locations. It'll be tight, but I think I can do it. Borrowing a friend's 60 watt iron for the motherboard, but I'll use my old Radio Shack 45 watt on the PSU's.
            • esqmooo
              HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
              by esqmooo
              Hello everyone.
              This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
              Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
              Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
              I tried long pressing on the power button, after several seconds it would go off then when the button is released...
              03-11-2025, 03:57 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Kiwi Viking
              HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
              by Kiwi Viking
              HP Elitebook 855 G8
              Product ID:4X5S2PA#ABG
              Motherboard M53301-601.
              Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
              When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
              03-01-2025, 01:05 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
