Battery charger - STIHL AL 300
  • YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    Hi friends,
    I got to fix STIHL AL 300 battery charger, for mower machines, which works fine only when the battery is discharged ( haven't tried it already, since I got only fully charged battery, but that's why I have been told ). When the battery has some % of voltage, the charger doesn't work. In this case, the red LED starts to flash 10 times, and there is no voltage at the output. The customer tried more batteries, and it worked like this with all tried batteries ( so looks like not a battery related issue ).
    I would try to discharge the battery ( with few 12V lightbulbs in series, since I don't have any device to fit it in ), and would try to confirm that claim, but I would try to diagnose the charger so far.
    Between the charger and a battery, there are three power supply wires ( one for positive and 2 for negative voltage ), NTC BAT wire and DATA wire. On the first picture, you can see the communication between devices ( green is DATA, yellow NTC BAT ) right after plugging in a battery. I wonder, if the issue is related to DATA communication and if so, if I am able to identify it somehow ( maybe compare the communication between charged and discharged batteries with logic analyzer? ). Or if it is related to battery voltage itself ( some voltage comparator on the board, etc ).
    Does anyone have any experience with this weird fault? I would be thankful for any hint. If you need some more info, feel free to ask. Thank you in advance.
  • CapLeaker
    Leaking Member
    • 8214
    Re: Battery charger - STIHL AL 300
    One piece of advice:
    Don’t go in diagnosing and breaking your head about something that you didn’t confirm, tried and couldn’t replicate.
    Why is this important? Because a hot battery will not charge in any state for example. In theory your customer could have tried to charge a hot battery and told you the thing isn’t charging. Same if things are too cold.
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      always best to read the instructions first with these things .. i do some 80v stuff as said the pack might be too hot .
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        the clue is on page 11 . https://cdn.badcaps-static.com/pdfs/...0c459ad215.pdf
        i have had to change a few temp sensors in the packs to get them to work .. also some chargers are picky about the battery packs . say if a pack wont work in one charger doesn't mean it wont work in another and visa versa .
        • YellowJacket
          • Dec 2020
          • 105
          • Slovakia
          Thank you all for your replies.
          As I mentioned, I have only one battery, and it is fully charged. When I tried to plug it in, the charger immediately started to flash red LED with some error code ( which says actually nothing useful according to manual, just to visit authorized service - the customer sent it there, and they said "buy a new charger"... I believe, they tested totally different battery packs, not this one ). The communication in attachments runs though, all time.
          So battery is in my room, where is around 25 degrees Celsius, its not hot, nor cold, during testing. I am trying to discharge it at the moment, with 4A load ( lightbulbs ), and will try to plug it in with various voltage levels ( I will let it cool down after discharging ). I will let you know, what I discovered.
          • CapLeaker
            Leaking Member
            • 8214
            The NTCBAT is the temperature for the battery.
            • YellowJacket
              • Dec 2020
              • 105
              • Slovakia
              Yes, I know. Actually, I don't know, why its value changes during communication with the charger ( yellow color in the first scope picture ).
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                check the connections .. it will flash red if it cant see the battery properly . maybe a bad solder connection or resistor gone high etc . do the light on the battery do anything ?
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  i have discharged packs with a 240v 600w lamp . its a bit slow but works .. best thing i found is a leaf blower to discharge them .
                  • YellowJacket
                    • Dec 2020
                    • 105
                    • Slovakia
                    I am on 32V ( 36V stated on the pack ), LED status on the battery shows 1 from 4 and it flashes ( so its fully discharged ), and I am unable to make it charge - customer said, it is charging only when a battery is discharged, so its not working at all now.
                    I have already made some brief visual inspection, for bad solder joints, etc, but haven't found anything suspicious. Will give it another try, more precisely this time.
                    ( discharging in my case is really fast, four 12V/55W light bulbs for a car )
                      • 31087
                      about that scope-shot.
                      why is a logic signal 14v?
                      and did you zoom in to see if that was data packets or just pwm?
                        • 31087
                        also does it try to charge? is the charger outputting power for a second?
                        maybe the mosfet is dead if it's not
                        • YellowJacket
                          • Dec 2020
                          • 105
                          • Slovakia
                          - 14V is directly on wires coming from the charger. I traced the connection to pin of some uC, and there is exactly the same waveform, but with max voltage around 4.5V
                          - yes, I zoomed out, and its for sure some digital data
                          - yes, it does try to charge, but only for very brief time ( fan starts to spin, LED on the battery starts flashing ), less than one second. I have voltage on the secondary side of a transformer. It starts to fall after the charger decides to stop charging though ( after plugging the battery in again, voltage on the secondary rises again for a brief time )
                            • 31087
                            any idea how old it is?
                            maybe small caps are dried out
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              i just remembered that the ones i work on behave like this if the battery pack is too far out of balance or too low voltage . they are supposed to go into a balancing program but i have never seen that happen yet .
                              also they do same if the temp sensor in the pack is faulty/broken .
                              sometimes you can jump the pack off a good battery and then charge it hopefully .
                              dont take much notice of the state of charge led.s as they can tell lies .
                              • CapLeaker
                                Leaking Member
                                • 8214
                                Try a known good battery for sanity sake.
                                  • Jul 2011
                                  • 6044
                                  What type of batteries are in this device
                                  • YellowJacket
                                    • Dec 2020
                                    • 105
                                    • Slovakia
                                    I have no idea, and customer aswell.
                                    @CapLeaker: this is a known good battery, I got from customer, he used it with different charger perfectly fine.
                                    Anyway, I observed a new fact - when I connect the charger to power source, there is no output voltage at the secondary side of a transformer! Before, I measured there voltage, but it was due fact, there is N-channel mosfet, between secondary and positive VBAT voltage, so after plugging the battery in, battery voltage appeared on secondary side via internal diode in that mosfet.
                                    So either, there is some problem on the primary side of a transformer, since there is no switching, or - I don't know, maybe it should start switching only after some condition is met? ( in my opinion - there should be switching right in a moment, when I connect the charger to power source, what do you think? ).
                                    I am going to dig around primary side now. Thanks for hints so far.
                                      • 31087
                                      time to fix the psu section - start with the caps
                                      • YellowJacket
                                        • Dec 2020
                                        • 105
                                        • Slovakia
                                        Main switching controller is L6599AD. I am afraid, I wont be able to diagnose anything without schematic - this controller is really complicated. It has 6V on VCC pin, but it looks like there are so many conditions, that have to be done, to make the controller start. It won't start switching at all, by the way. Without or with battery plugged in. Mosfets are fine.
                                        Measured voltage ( no battery plugged in ) at all pins are 0V, except:
                                        7 = 1.2V
                                        12 = 6.2V
                                        16 = 4.2V
                                        Am I understanding datasheet correct, when I say, that after VCC, there should be ramping up some other voltages? Datasheet page 25.
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                          Bauer tool battery pack charging with a HERCULES charger modification
                                          by sam_sam_sam
                                          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                          05-06-2023, 12:17 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                          Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                          by sam_sam_sam
                                          I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                          So I have put them on the battery testing machine to drain each battery cell down to...
                                          09-04-2022, 04:45 PM
                                          Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                                          The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                                          The bq24745 features dynamic power management...
                                          10-23-2024, 02:50 AM
