dewalt battery powered radio - no power at board
  • geoff69
    • Dec 2019
    • 14
    Hi hoping you can point me in the right direction
    Powerboard not outputing voltage to main board.
    Looks like battery voltage comes in and runs through a battery discharge protection circuit triggering a P-Channel Mosfet NCE40P13S for output to main board.
    Uses C3 pin on battery which I think is one of the cell voltages
    Input from battery is 20V fully charged
    Seems like there is full battery voltage at the gate of the mosfet, nothing on the drain and full battery again on the source which doesn't seem right.
    The two diodes on the output of the mosfet seem to be ok.
    Some of the solder points look balled - but compared to other boards ive seen this seems to be common or from factory?
    Any tips on fault finding and understanding the way this circuit works please would be appreciated.
    • 31183
    Re: dewalt battery powered radio - no power at board
    what are the 4 large center pads for?
    i can see something was pressing onto them.
    • geoff69
      • Dec 2019
      • 14
      Nothing, test points?
      Here are images of the reverse of the bird and also the board in situ showing no contact with anything else
      • CapLeaker
        Leaking Member
        • 8321
        Probably it’s not getting the command to turn on. Check things like the power button and that circuit going to the controller
        • geoff69
          • Dec 2019
          • 14
          Probably it's not getting the command to turn on. Check things like the power button and that circuit going to the controller
          There's no comms going to the board, just a two pin output - no enable signal
          The fet needs a differential between gate and source to turn on - spec says typical -2.5v
          Tested it has battery voltage at both
          • CapLeaker
            Leaking Member
            • 8321
            Aaah! Gotcha! It’s just a plain battery low voltage cut off board. Well, with 20v on the gate of a p channel mosfet, yes, she will not switch. The gate drive Q5 and Q6 are mosfets too. They use the mosfet as a switch. Not sure if you looked at these resistors yet.
            • geoff69
              • Dec 2019
              • 14
              Aaah! Gotcha! It's just a plain battery low voltage cut off board. Well, with 20v on the gate of a p channel mosfet, yes, she will not switch. The gate drive Q5 and Q6 are mosfets too. They use the mosfet as a switch. Not sure if you looked at these resistors yet.
              all resistors look sensible values
              found short between two pins of the little (sop25?) 5 pin ic
              re flowed and removed the short but still not joy
              anyone know what this ic is and what its doing?
              Marked B8PW but google isn't having any joy
              • CapLeaker
                Leaking Member
                • 8321
                maybe do some measurements on these pins
                • R_J
                  • 9588
                  It seems to be a S-80830CNMC voltage supervisor 3V , pin 2= Voltage input pin 3= ground
                  • geoff69
                    • Dec 2019
                    • 14
                    Seem to be same as initial measurements
                    on a fully charged battery >
                    pin 1 - 18.67v
                    pin 2 - 20.5v
                    pin 3 - 16.42v
                    • geoff69
                      • Dec 2019
                      • 14
                      ahh interesting
                      if thats correct it would make sense that it uses the differential between battery + and pin c3 on battery to detect single cell voltage and cut off if below 3v?
                      on a fully charged battery I have >
                      pin 1 - 18.67v
                      pin 2 - 20.5v
                      pin 3 - 16.42v
                      Vdet is essentially 4.1v in this case referenced to battery pin c3 rather than battery negative - and I'd expect VOut to follow Vdet which it isn't?
                      The short I had between pin 1 and pin 2 shouldn't have caused a problem other than turning it off - is that correct?
                      • petehall347
                        • Jan 2015
                        • 4436
                        • United Kingdom
                        try measure voltages using pin 3 as reference .
                        • geoff69
                          • Dec 2019
                          • 14
                          in which case we have
                          4.1v VDD Pin 2
                          3.7v OUT Pin 1
                          • geoff69
                            • Dec 2019
                            • 14
                            I've tried to draw out the circuit from the left hand side of the board
                            I've taken the values of the resistors as measured and they're close to the smd codes
                            transistors are two channel p and an n
                            Is it any help? I can't follow whats happening
                            • CapLeaker
                              Leaking Member
                              • 8321
                              I suggest you read that datascheet of the voltage detector very carefully. There is a theory on how this thing works, simple test circuits etc. what happens if you use a pull down resistor on the output?
                              • geoff69
                                • Dec 2019
                                • 14
                                From what I can tell >
                                If it is that particular voltage detector and not something else …
                                There is a voltage detect value in this case defined at 3v with upper and lower hysteresis values to prevent oscillation. Vdet being 3v with min -Vdet and max +Vdet
                                If vdd is below operating voltage the output is undefined
                                Otherwise output follows Vdd or Vss depending if Vdd is above or below Vdet - switching on the upper and lower bounds of +-Vdet values
                                Test circuit just seems to be a 100k resistor between output and Vss
                                I can't see a scenario where output is somewhere between Vdd and Vss as measured unless it's below operating voltage and therefore undefined or floating about?
                                There's a good chance I'm missing something obvious though so I am more than open to being corrected
                                • geoff69
                                  • Dec 2019
                                  • 14
                                  SOLVED
                                  Replaced output pmos NCE40P13S and now working
                                  R5 looked suspect as measured only 674ohms vs expected 2M ohm and is across the gate and source
                                  Thanks for all your help
                                  • CapLeaker
                                    Leaking Member
                                    • 8321
                                    Awesome!
                                      • 31183
                                      now the only remaining problem is finding something worth listening to.
                                      although if it's used in London you have all the R&B stations.
                                      • geoff69
                                        • Dec 2019
                                        • 14
                                        Hah, I think it'll be getting a bluetooth board stuck in it now, its got an aux input I can commandeer - if I can find a 5v rail on the board I'll stash it inside somewhere
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • kodox
                                          ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                                          by kodox
                                          since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                                          the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                                          what i've done:
                                          - flashing...
                                          12-29-2024, 02:49 AM
                                        • Crrose
                                          How to test circuit board battery connection.RS-4i sequential stimulator
                                          by Crrose
                                          Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand...
                                          03-21-2023, 03:55 PM
                                          DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
                                          09-06-2024, 05:40 AM
