ICE3B0365J Troubleshooting (W200 Sub)
  • R_J
    • 9607
    Re: ICE3B0365J Troubleshooting (W200 Sub)
    Originally posted by SFB
    Scratch that, I left it alone for an hour and it suddenly started working again...the behavior of this board has me baffled.
    Just left it with the volume up full (low input so as to not annoy the neighbours), after a few minutes it cut out went to flashing and then kicked back in again after a few seconds...going to leave it running and monitor it.
    Have you checked the AMP board? I suspect a poor connection on the amp board may be causing it to go into protection.
    • CapLeaker
      Leaking Member
      • 8340
      Post some pictures of the amp board. Maybe there is a cold solder joint somewhere there?
      • SFB
        • Mar 2023
        • 48
        • United Kingdom
        #43
        I did have a look at it but didn't see anything obvious - it is all SMD (pictures attached - Ignore the yellow and orange wires as they are just extending the LED cable as it is only just long enough to connect when the case is closed)
        Measured voltages on the 102 cap in the bootstrap on the 51ohm - When it works 188V, when it does a false start and stays constant red (he said it has always done this at times and he needed to restart) 162V, and when it is flashing red a pulsing reading from 158-240V. It is working more than not after switching out the R31, R38 and R40 resistors with 1/4W metal ones, and was actually a challenge to get it to flash - leave it on a while then a fair bit of on/off.
        It seems I'm creeping closer to a resolution...
        • CapLeaker
          Leaking Member
          • 8340
          Ok… I wanna know which board is causing this. If you look at your first post, the second picture. Look at the secondary side of the optocoupler. One leg traces back to a pin on the amp board. Check it out. Somewhere it looks like there is a half broken trace. Maybe worth resolderig the whole line up.
          • SFB
            • Mar 2023
            • 48
            • United Kingdom
            #45
            I had actually resoldered from that point up to the pin when I did the rest recently as I had noticed the broken bit, but with you mentioning it I decided to run wire down and it seems to have done it. Been on over an hour and cannot get it to turn red or flash. Not counting my chickens yet and going to mess with it more, but tentatively hopeful...
            • SFB
              • Mar 2023
              • 48
              • United Kingdom
              #46
              It's gone again, but only once I had put it back inside for half an hour...it has got to be a heat issue....going to heat and freeze stuff tomorrow.
              • CapLeaker
                Leaking Member
                • 8340
                Dang. Would have been too good to be true. Lol
                • SFB
                  • Mar 2023
                  • 48
                  • United Kingdom
                  #48
                  Yeah, starting to get on my nerves a bit now haha
                  • CapLeaker
                    Leaking Member
                    • 8340
                    Obviously something is turning the PSU off? Maybe force it to stay on?
                    • SFB
                      • Mar 2023
                      • 48
                      • United Kingdom
                      #50
                      That would blow something though wouldn't it? It is obviously tripping because it is detecting an issue.
                      I can't even get it to come on again now...I don't understand how laying a bit of wire to re-enforce a tracer, desoldering-checking-resoldering, reflowing connections, just taking measurements or even having the board outside/inside can completely change it's behaviour. So far I have had it working, static red light, slow flashing red light, fast flashing red light or nothing at all, and completely random combinations of all or some of them.
                      I imagine if it was the other board you wouldn't see this happening as there are no changes happening there?
                      • CapLeaker
                        Leaking Member
                        • 8340
                        Right now I wouldn’t care much if something blows up and we don’t even know why it shuts down.
                        • SFB
                          • Mar 2023
                          • 48
                          • United Kingdom
                          #52
                          Fair point. I'm assuming to force it to stay on I'd need to inject the 15V on the VCC connection, or the expected voltages on the pins for the amp board. Would mean I need to get myself a desktop PSU...a thermal camera would be helpful too, but no way I can afford one of those at present haha
                          • CapLeaker
                            Leaking Member
                            • 8340
                            There are cheap CV and CC bench PSU’s available. This way you could adjust the current too.
                            • SFB
                              • Mar 2023
                              • 48
                              • United Kingdom
                              #54
                              I think I've got it. Before getting a bench PSU and forcing it I decided to take the last bridge off as it was working better prior to no avail, then went round and reflowed every single connection (some bubbled) before doing a meticulous clean with alcohol and qtips. Worked straight away but after an hour it stuttered and noticed some molten flux had seeped out of somewhere, so cleaned that and now it has been solid for 19 hours inside the unit. Just cleaned up a few more bits of liquid flux and still solid. Would have liked to say it was a join, but it looks like flux somewhere has been melting when it gets hot and tripping it. I have been cleaning the board every time but can only assume with the board damage it had gotten somewhere I was missing while cleaning. Is that likely?
                              • CapLeaker
                                Leaking Member
                                • 8340
                                I ran into this exact same issue on an old nortel telephone system. The fix was to take the component out, clean the hole and resolder it. Funny thing is this system worked for like 15 years no problem before this issue rose up.
                                Just resoldering that component didn’t help and leaked old flux like crazy.
                                • SFB
                                  • Mar 2023
                                  • 48
                                  • United Kingdom
                                  #56
                                  Jeez...no wonder it was being intermittent and everything else checked fine then. Definitely something I'm going to keep in mind for future though if the issue is being elusive. He has taken it now and it hadn't faltered in over 24 hours. I did notice residue on the back plate during that last clean so hoping whatever it was I either got or just burned off with the heat. I have learned a lot though, and thanks again for your help and advice with this, it is very much appreciated. Suppose it is back to my sub now then and try and figure that out now haha
                                  • CapLeaker
                                    Leaking Member
                                    • 8340
                                    I found the problem using my oscilloscope and my hot air station. Hopefully that fixes it now for good.
                                    • SFB
                                      • Mar 2023
                                      • 48
                                      • United Kingdom
                                      #58
                                      An oscilloscope and a bench PSU are the 2 things I don't have, though the latter is planned as soon as I have some spare cash. I have seen some reasonably priced secondhand scopes but right now I wouldn't know how to use one anyway lol
                                      • Cemal Odabasioglu
                                        MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                        by Cemal Odabasioglu
                                        I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                        Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                        Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                        Observations...
                                        01-14-2025, 03:54 PM
                                      • triplefour
                                        ONN 100012588 Has fluctuating Voltage on PSU 12v
                                        by triplefour
                                        Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                        anyway i go to this guys house to look at an ONN 100012588
                                        this is my first time looking at one of these brand of TV's.
                                        TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                        09-14-2022, 07:41 PM
                                      • blues_spirit
                                        practical courses for troubleshooting pc motherboards
                                        by blues_spirit
                                        Hello from France,
                                        mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                        Do you think this is feasible for me? I...
                                        12-18-2022, 12:56 PM
                                      • beetle1303
                                        Wine Chiller - SMPS issue - fluctuating voltages
                                        by beetle1303
                                        My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                        Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                        Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                        Checking further on the primary side: Incoming line input to bridge...
                                        09-04-2023, 10:33 AM
                                      • gcrezz
                                        GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
                                        by gcrezz
                                        The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
                                        07-25-2024, 09:49 AM
