Hello...
I got my self a dead CM V700 PSU, with nothing on +5vsb
I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
I have read the datasheet and and still can not understand how it work...
I believe the VCC should be higher, but after everything i done, still nothing
Things i have done :
Replace ICE2QR4765
Replace the startup cap
Remove and measure both snubber Diode and Vcc diode from Aux winding
Remove and measure both CS resistor and ZC resistor
Replace output cap
Remove and measure output diode
and everything was OK
I believe the aux winding is responsible for creating VCC line for the ICE2QR4765
I trace the vcc rail.. one goes to ICE2QR4765, to control board and to pfc area..
I suspect that there is some kind of short that dragging the voltage down, and when i inject with 5v, got no load.
I also suspect that the transformer is bad... when i measure the primary winding i got 1.90 Ohm, is it normal ? and .035 Ohm on Aux 0.22 on Sec
when i measure the output, i got no voltage reading at all... and the output rail got no short.
From my understanding, the +5vsb should be up first and the other will follow (CMIIW)
So If anyone have any idea or suggestion on what i should do next, please advise...
Thank you
Replace ICE2QR4765
Replace output cap
Thank you
