Stupid question...replace 10v with 6.3v?
  • yyonline
    • Jul 2009
    • 692
    So, I've never bothered to recap a power supply before. I took one of my PCs offline for awhile as I'm waiting on a HD RMA from Western Digital. I'm taking the time to go over it, clean out the dust bunnies, etc.
    It has an Antec Basiq 430 watt PSU. It's one of the Delta built units.
    I opened it up. It's a weird mix of caps. At least half of it is good caps - Rubycon and Chemi-con and a Samxon primary. The other half it Ltec and Aishi.
    So, I'm going to replace the Ltec and Aishi as a preventative measure, and swap out the sleeve bearing fan for a ball bearing fan.
    There is one cap that is 10V 2200uF. Looking at what caps I have at the moment... can this safely be replaced with 6.3V 2200uF? I know you can substitute 6.3 for 10V on motherboards, as long as the ESR/ripple specs are sufficient. Does the same hold true for power supplies? I would think so, since a 10V cap can only be on a 5V rail. But I also wanted to verify with those who do this more often than I do.
    Thanks!
  • Quasar
    • Sep 2010
    • 132
    Re: Stupid question...replace 10v with 6.3v?
    They use higher voltage caps because they are cheaper in many cases. Check and make sure it doesn't exceed 5 volts on that cap and you should be fine. A 20% over-voltage buffer would be 6 volts, so 6.3 would be fine. Look up the specs and compare what was there to what you are using for ESR and ripple.
      • 31017
      ripple &esr will be worse because of the reduction in size - i wouldnt downsize it.
      your not leaving much margin for the voltage ripple anyway - so it will run hot.
      • Quasar
        • Sep 2010
        • 132
        There is no mention of size reduction by yyonline. Actually, there is no mention of any specs except for voltage and capacitance. No series identification of what is there and no info on the replacement to be used except again, the voltage and capacitance.
        If the same size as original and a better grade of cap, the capabilities would be equal or better.
        If the original has a ripple rating of 2000 ma and the replacement is equal or better, it won't run any hotter.
          • 31017
          6.3v on a 5v rail is too close, 6.3v on a 3.3v rail is o.k. - another thing to take into acount.
          as a rule, an electrolytic should be rated at 1.5x running voltage as a minimum to allow for voltage spikes without reducing the life of the cap.
          • Quasar
            • Sep 2010
            • 132
            If 5 v reaches 7.5v, you probably killed the $150 motherboard. Screw the 10 cent cap.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Ripple and ESR will only be worse if you down size -and- stay with the same ESR grade of cap.
              You can usually down size and improve ESR/Ripple by using a grade of cap that is better than original cap.
              Have to look up the specs on the original to know though.
              A smaller diameter cap with the same or higher Ripple rating than the original is actually a good thing as more air flow [hence cooling] can get around the cap.
              A 6.3v cap on a 5v rail is standard practice even for original caps.
              Is not a problem at all.
              Mann-Made Global Warming.
              - Dr Seuss
                • 31017
                on stuff with a 5year lifespan maybe, i work on stuff 30years old.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Bogus.
                  Same old and new.
                  - Dr Seuss
                  • berniedd
                    • Mar 2007
                    • 119
                    I've done dozens of 10v replacement by 6.3 v caps. You will be fine so long as you use the same capacitance or even slightly better than the original.
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
                    • Antonynl
                      What are typical ripple voltages on a laptop motherboard?
                      by Antonynl
                      I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                      So I have two questions:
                      1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                      2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                      Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                      12-09-2022, 06:51 AM
                    • Ady2017
                      Is there a manufacturers tolerance for ripple?
                      by Ady2017
                      Hi all
                      I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
                      As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
                      The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
                      11-13-2021, 11:46 AM
                    • Antonynl
                      Lenovo 530 Vcore : what is the maximum ripple?
                      by Antonynl
                      Hi
                      I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
                      Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
                      What is normally the maximum ripple allowed on say any of the power supplies? A few %??
                      The ripple is on both Vcore as outlined in red in attached photos.
                      Could be a bad driver?
                      Cheers...
                      04-29-2023, 04:59 AM
                    • sumilumi
                      700mv ripple on Akai Sampler linear supply
                      by sumilumi
                      Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
                      I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
                      On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
                      01-02-2022, 10:12 AM
