Xbox 360 PSU failure diagnosis
  • nick122
    • Jul 2016
    • 110
    • Slovenia
    Hi everyone!
    I recently got a bunch of 360 accessories for a good price, among which was also this PSU. It's a unit is rated for 175W (14.2A). OEM is Liteon.
    The unit briefly powers on for a few seconds, the green light comes on, and powers back off shortly after the green light changes to red. There is no output voltage, I can't hear the fan running either.
    Upon opening it up, there is nothing that would indicate why the unit failed. No burn marks, everything looks good visually. Primary cap is 130uf 450v NCC KMG, secondary caps are 1500uf 16v TAICON, all of which look good too. It appears to be using a continuous topology, judging by the inductor on the secondary. It uses a single switching MOSFET, which is a Toshiba K3569. I appears to be using a single forward topology, as I couldn't spot a capacitor in series with the primary transformer (assuming the transformer acts as an inductor). Somebody please correct me if I'm wrong.
    On the secondary we have 2 N-channel MOSFETS for asynchronous rectification, an inductor and output filter caps.
    The single switching transistor is driven by a surface mount PWM controller at the underside of the board. I used a multimeter to check the zero fuse resistors, and have found 2 to be blown (I replaced them with jumper wire). They connect the PWM controller through an optocoupler, which are probably part of some voltage feedback circuit. It suggests that something might be shorted, maybe the PWM controller? I can't quite tell the markings on the PWM chip, but it appears to be an IR part.
    Any suggestions are highly appreciated.
  • CapLeaker
    Leaking Member
    • 8321
    Re: Xbox 360 PSU failure diagnosis
    To me there shouldn’t be anything majorly wrong on the primary side of the PSU. The mosfet can’t be shorted otherwise the main fuse would be blown. As far as I understood, the PSU turns on, then off… which means it tries to start, but then fails. So the primary must work, because you get a green light for a few seconds. There can be a few reasons why it does this. I’d check if there is a short on the secondary first, check the output caps, then check the main filter capacitor on the primary and the starter cap.
    • nick122
      • Jul 2016
      • 110
      • Slovenia
      Thanks for the reply! I just checked the secondary side, there's no short. The caps test fine and the MOSFETs aren't shorted either. They're wired in parallel. I also took some more pictures of the whole board.
      As you said, the primary switching MOSFET appears to be good too. I'm still confused about this PWM controller chip, as I can't find anything online. It appears to be an IR part though.
      • nick122
        • Jul 2016
        • 110
        • Slovenia
        Update: I found this strange (to me) inductor(?) that sits in between the transformer output and the output filter, it seems to just be a copper bridge running through a ferrite core, which is wound with thin wire. The small coil seems to be controlled by some SMD MOSFETs. Is that supposed to improve efficiency compared to a regular coil or is it something completely else?
        Update 2: I tested the optocouplers, and they appear to be good too.
        Update 3: The PWM controller is NCP1377, not sure why i kept thinking it war an IR part.
        • lotas
          • Jan 2016
          • 4743
          • Russia
          This is not an inductor, this is a current sensor, a current flows through a thick wire, and a coil with a thin wire reads this current and when the current increases (load or short circuit at the output), the circuit blocks the output power.
          • nick122
            • Jul 2016
            • 110
            • Slovenia
            Thanks for letting me know! In that case, this PSU definitely uses a discontinuous design.
            • CapLeaker
              Leaking Member
              • 8321
              If you didn’t find anything wrong yet, look at the feedback from the secondary back to the primary. The PWM in the primary also has some special features like undervoltage cutout, OVP etc… As you see there could be tons of reasons why this PSU isnt working.
                • 31183
                i dont want to spoil the fun, but how was it tested?
                the 360 psu has a main SWITCHED output and a seperate standby supply,
                is the standby running?
                how did you try to activate the main output?
                what load did you use?
                • nick122
                  • Jul 2016
                  • 110
                  • Slovenia
                  Thanks everyone!
                  @CapLeaker I have checked everything on the primary side. The only clue that I have are the 2 blown zero fuse resistors in series with the PWM chip VCC. NCP1377 VCC to ground measures 300k, so it's not a dead short. What else could cause these resistors to fail? I've replaced them with some wire, but that only made the third resistor in series blow. 5vsb, which uses the same power source, works just fine. This leads me to believe that there's something wrong with the NCP1377 PWM chip. What do you think?
                  Here's a quick and dirty schematic I drew:
                  @stj I get standby voltage, but when I try to power the 12V rail by shorting PWRGD to 5VSB, the light turns green, and shortly changes to red. Even when it's green, there's no 12V output.
                  P.S. The main 12V power supply is definitely a flyback.
                  • lotas
                    • Jan 2016
                    • 4743
                    • Russia
                    Check the resistance at these points.
                      • 31183
                      i have a feeling the power on signal should be 3.3v - use a resistor
                      • CapLeaker
                        Leaking Member
                        • 8321
                        Pin 8 of the NCP1377 PWM should have high voltage and that is where the 0 ohm resistors come in play. I am thinking the PWM is bad. I’d make sure that the mosfet and the gate drive is o.k., replace the 0 ohm resistors and the PWM and pray nothing else is bad.
                        What caused it? Could be a few scenarios starting from a lightning storm and ending by dirt accumulation and dampness between the HV pin and a different pin of the PWM.
                        • TMTGTR
                          An Xbox One PSU Odyssey
                          by TMTGTR
                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                          =>Background:
                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                          06-17-2022, 05:40 PM
                        • ohren
                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                          by ohren
                          Hello!
                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                          Measured voltages with no load:
                          After rectifier diodes
                          12V: 6.17 V
                          5V: 5.67 V
                          Secondary transformer pins AC measurement (really don't know if this says anything)
                          12V: 2-2.5 V
                          5V: 1.04 V
                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                          03-18-2023, 10:33 AM
                        • holgerczukayfan3000
                          Thinkpad T14s RAM failure diagnosis
                          by holgerczukayfan3000
                          Hey there,
                          my Lenovo T14s i7-10510 16GB Ram is behaving very unstable. Checking the errors with memtest86+ returns bad adresses all over the memory although it's 8 discrete modules. Somehow i have doubts that the error is rooted in the RAM devices themselves but more in the way they're organized. i'll attach a badram dump from 4 scans.
                          is someone here who's familiar with issues like that? all the memory devices are soldered with BGAs. not sure if replacing them is actually an option.
                          i know about electronics, not so much about digital and small things. but also happy...
                          03-17-2025, 09:45 AM
                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                          09-12-2024, 02:00 PM
                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                          by momaka
                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                          03-29-2022, 11:34 PM
