Ordering caps to recap power supplies.
  • seanc
    • Nov 2008
    • 1319
    Re: Ordering caps to recap power supplies.
    Looks like I should take out as much as possible and replace with Panasonic FK then.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Panasonic FK are great for PSU use. Wish I could get them here.
      The FK series has a 2700uF 10v and a 2200uF 16v that are 10mm.
      Mann-Made Global Warming.
      - Dr Seuss
      • seanc
        • Nov 2008
        • 1319
        Wow, I'm really surprised. Seems you can only get the SMT type.
        Thanks for your help. Is there anything you would recommend reading about this subject?
        I'm just starting out on my electronics course... give me time. Sorry for the hijack!
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          And 3300uF 6.3V 10mm that I use for 5V and 3.3V
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Farnell has them in Europe but they charge too much to ship to the US.
            http://uk.farnell.com/jsp/search/bro...lues%3D1000224
            - Dr Seuss
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
              by momaka
              03-15-2023, 10:17 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • fl0w
              GeForce 6800GT recap, need help identifying caps and finding replacements
              by fl0w
              I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
              But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
              I need to replace:
              • 2x 2.5V 1500µF => I plan to use this
              • 2x 16V 330µF=> I plan to use this
              • 1x 6.3V 680µF=> I plan to use this
              Am I correct with the cap choices?
              Thanks for...
              10-02-2024, 11:28 AM
