Mobility scooter charger dead 6240803
  • DiamondTech61
    • Aug 2021
    • 61
    • united kingdom
    Hi I have a mobility scooter charger that's dead, uve checked the main fuse and internal fuse which are fibe, the main capacitor is showing about 320v on its output but I have no idea what to check next, hopefully someone can help with the supplied pictures
  • CapLeaker
    Leaking Member
    • 8195
    Re: Mobility scooter charger dead 6240803
    explain exactly what you charger is or is not doing. for example is it stone dead, are these LED lights doing anything? Etc. Is the secondary shorted because someone hooked it up backwards? Each little information counts.
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      this dont look good .
      • DiamondTech61
        • Aug 2021
        • 61
        • united kingdom
        Its stone dead, no LEDs or anything.
        • DiamondTech61
          • Aug 2021
          • 61
          • united kingdom
          Thanks for pointing that out, Ill look into that and give it a clean up and resolder
          • CapLeaker
            Leaking Member
            • 8195
            There are a few fuseable resistors with a zero ohm value, rectifier diodes, fets and a few small bridge rectifiers. Check those. You got power laying on the main filter capacitor, right?
            Forgot to mention, resolder all transformers and anything that has some weight to it.
            • DiamondTech61
              • Aug 2021
              • 61
              • united kingdom
              ok, ill start with the easy option first by cleaning up and soldering, can someone maybe draw a rough path of the power going through? Should the 2 big coils be DC? Also, what's the best way to discharge the main capacitor, is it just a 1w resistor across the points? Ive just been leaving it to discharge slowly but it takes ages, thanks for all your help and info!
              • DiamondTech61
                • Aug 2021
                • 61
                • united kingdom
                ok so Ive soldered all the connections and its still the same, im not really sure what to check next
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  is that a crack ?
                  on another note some chargers wont start if the battery is too low .
                  • DiamondTech61
                    • Aug 2021
                    • 61
                    • united kingdom
                    Hi, no its not cracked, I think it's just the light in the pic, it used to have leds light up but now nothing. I'm guessing it HAS to be something on the right half of the board as 300v is going to large capacitor. I have no idea what to test on it, could someone maybe draw on it where to test? I need an idiots guide 🙄
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      how low is the voltage of the battery pack ?
                      • DiamondTech61
                        • Aug 2021
                        • 61
                        • united kingdom
                        I would have to check but I know it charges fine from another charger
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          ok just trying to rule out simple things first .
                          • DiamondTech61
                            • Aug 2021
                            • 61
                            • united kingdom
                            No I understand completely, Ive made silly mistakes like that in the past lol
                            • DiamondTech61
                              • Aug 2021
                              • 61
                              • united kingdom
                              can someone maybe draw on the pictures the route of the power and where I should be measuring?
                              • CapLeaker
                                Leaking Member
                                • 8195
                                I've circled stuff to check. Start with the small bridge rectifier and the 2 caps near the LEDs.
                                • lotas
                                  • Jan 2016
                                  • 4623
                                  • Russia
                                  Check the primary resistance (1-2) on the transformer, it has an internal fuse and it may have blown.
                                  • BTubbs200
                                    Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                    by BTubbs200
                                    Dell Latitude 5420 P137G
                                    Board: LA-K491P REV A01
                                    I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                    Board seems to have no shorts, all power rails are fine and show high resistance.
                                    When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                    01-24-2025, 08:15 PM
                                  • motormayhem
                                    Lenovo T460 Only Charges on One Charger
                                    by motormayhem
                                    Laptop Question
                                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                    05-12-2023, 01:46 PM
                                  • dellxps15
                                    macbook a1707 15 inch trackpad dead. blown fuse identification
                                    by dellxps15
                                    hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                    another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                    04-30-2024, 10:48 AM
                                    NVDC charger configuration...
                                    11-05-2024, 03:28 PM
                                  • Golden2000
                                    42v xiaomi scooter charger
                                    by Golden2000
                                    I have 42v charger , it outputs about 14v not 42v what i can check to start repairing it ?
                                    09-30-2024, 05:42 AM
