Unknown component in 19V power supply
    • Jul 2011
    • 6040
    Re: Unknown component in 19V power supply
    If you have the ESR meter from the same company then check it with that if you get “0” then you might be on something but it still might not be bad but maybe questionable
    • rddube
      Aspiring Expert
      • Jun 2013
      • 940
      Ok, so I checked the power winding with my blue ring tester and that measures good. I checked resistance of the power winding which is +- 1 ohm and the output winding is +- 1 ohm. The other winding which is I guess the feedback winding measures also +- 1 ohm, but shows short on the blue ring tester.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 940
        Hi Sam,
        No I don't have an ESR meter from the same company. I do have an ESR meter however from another company - what should I check the power winding or the output?
        • lotas
          • Jan 2016
          • 4620
          • Russia
          This tester only checks the power winding for an interturn short circuit!, on others, the winding will always show that the transformer is not working.
          If the tester has green LEDs on the power winding, this means that the transformer is working, but if you close the secondary windings, the green LEDs will go out.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 940
            So since I am getting 12v on the VCC pin 5 of the LD5533 and no output on the out pin 6 (0V), do you think that LD5533 could be the culprit?
            I did check the output pin path of the LD5533, it goes to a 30 ohms resistor and then to a 100 ohm resistor to finally go the the Gate pin of a 2SK3569 mosfet, who's source goes to the power winding of that transformer.
            What do you think?
            • rddube
              Aspiring Expert
              • Jun 2013
              • 940
              What do you think?
              The 30 ohm resistor and 100 ohm resistor measure exactly what they should. Any thoughts anyone?
              • R_J
                • 9551
                What do you think?
                You need a scope to see the output of the ic to see if the 130kHz signal is there to drive the mosfet gate.
                The VCC needs to be above 16v as per the datasheet to turn ON then can not fall below 7.5v. Does the VCC pin get above 16v when power is supplied? if not the ic will not start, this could be due to a bad ic. There is an internal 31v zener built into the ic so it might be damaged, or check the resistor RX1 (1.8M) between the main bridge rectifier and the vcc pin, maybe it has gone high in value. (same as R5,R6 in schematic)
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 940
                  Hi R_J,
                  VCC goes to 18V when powered on, and then falls to 12V. Resistors all seem fine at their given values. Do you have a schematic for this? Tks!
                  • R_J
                    • 9551
                    Hi R_J,
                    Yes I have a schematic, and so do you. Its not exact but looks very close
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 940
                      Hello R_J,
                      Not sure what you mean by I have a schematic too? Do you mean the datasheet of the LD5533?
                      • R_J
                        • 9551
                        Hello R_J,
                        Yes, Have you looked at the datasheet ?
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 940
                          Ah ok, I looked at the datasheet but mostly for the pinout of the LD5533. Had not looked at the schematics further down. Will try and trace that and make it correspond to my device. Will report further. Tks!
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 940
                            After removing LD5533, I get 44V on pin 5 VCC, and when I reinstall LD5533, VCC drops to 12V and is not stable jumps from 14V to 12V. I checked for shorts on the chip itself, non, checked the path of every other pin to see if anything might be shorted, nothing. So I think the LD5533 chip is bad. What do you think?
                            • R_J
                              • 9551
                              There is no way to tell by checking with a meter, they are a very complex ic. Without being able to see the output, it is likely best just to replace it. If there is no voltage at all on the secondary side, I suspect there is no output from the ic to switch the mosfet, even if it was detecting a fault, there should be some voltage on the secondary side, even a few volts.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 940
                                No it's giving absolutely nothing, completely dead on the output. I ordered the chip, coming from China so probably a month or 6 weeks should be here. I'll keep you posted. Thks!
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 940
                                  Got a reply from China that the LD5533 is out of stock. Searched the web, Ebay, Aliexpress, Yoycart, etc. and can't find it for sale! Anyone have any idead what I could use as a substitute or do you have any other sources where I can maybe find it?
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 940
                                    Was able to identify a substitute for the LD5533 with a LD7537RGL - not exactly the same but close, so on their way. Will keep you posted. Tks!
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 940
                                      Ok, so got the LD7537RGL in yesterday, changed it and still no go. Nothing on the output and the input pin has 12-15v oscillating.
                                      Not sure what to check next.
