Unknown component in 19V power supply
  • rddube
    Aspiring Expert
    • Jun 2013
    • 940
    Anyone have any idea what this component is in an Acer Swift 3 laptop power supply?
    Many thanks!
  • R_J
    • 9535
    Re: Unknown component in 19V power supply
    Why multiple posts for the same problem?
    Your answer is below
    • lotas
      • Jan 2016
      • 4601
      • Russia
      Ld5533h
      • rddube
        Aspiring Expert
        • Jun 2013
        • 940
        Sorry, I thought I hadn't posted it in the right section. Should I delete one of them?
        • rddube
          Aspiring Expert
          • Jun 2013
          • 940
          Originally posted by lotas
          Ld5533h
          Thank you Lotas!
          • R_J
            • 9535
            No it's ok, you can't delete threads
            Why do you suspect this ic is bad? What voltages etc. have you checked so far? Check that you have voltage ACROSS the main filter cap (165vdc)
            See the pdf, the output should drive a mosfet's gate, There will be a resistor from the mosfet source to ground, check that it is not open, it should be around 1Ω or less If it IS open the mosfet is likely shorted, if it is ok then I suspect the problem is elsewhere.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 940
              Hello R_J!
              Across the filter cap I am getting 166V.
              I am getting 12V on the VCC pin (pin 5) and 0 on the output (pin 6). Where is the source pin? Do you mean CS pin 4?
              Many thanks for your great advice!
              • R_J
                • 9535
                You would need to provide pictures of both sides of the circuit board to start troubleshooting.
                12v on the vcc pin is good You would need a scope to see what is on the out pin for drive. The out pin should connect to a mosfet gate. This ic can not drive the transformer directly.
                The source pin is on the mosfet, the CS pin will connect to it via a resistor.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 940
                  Hello RJ,
                  Tried to take pictures, on one side the one in the picture there was a lots of white hard glue that I had to remove. I discovered under the glue a damaged RS1M diode and since I didn't have a RS1M I replaced it with an FR107 diode. You're right, the out pin connects to a mosfet gate, as you will see in the photo (i removed the mosfet and C6, which I will replace), but I have 0V at the output of the mosfet. Here is a photo with some explanations. Tks!
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 940
                    Also, not much purpose on taking a photo of the other side, it is filled with glue and you see absolutely nothing. I would have to remove all that glue and it is a mess. Here is a photo anyways.
                    Tks.
                    • R_J
                      • 9535
                      There seems to be a bad solder connection on a component, can you check what it is and where it connects?
                      What do you mean RS1M diode was damaged, physically broken, shorted, open? Looks like it could be D2 on the datasheet schematic
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 940
                        That is one of the legs of the little transformer, and it is not connected, no solder point there.
                        When I removed the glue, the RS1M diode lid just came off. Is the photo clear enough?
                        • R_J
                          • 9535
                          The transformer primary is connected between the + of the bridge rectifier and the mosfet drain, there should also be a feedback winding that supplies run vcc voltage for the ic. One end of the feedback winding connects to hot ground the other feeds a diode and then pin5 of the ic
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 940
                            Ok, so what do you think I should be checking next?
                            Tks.
                            • R_J
                              • 9535
                              Did you check the feedback circuit? You did check to make sure there was no shorted output on the secondary side, like shorted cable, shorted output diode etc.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 940
                                Still learning R_J, what does the feedback circuit look like? I'll check for shorts on the secondary side of the transformer and report back.
                                • R_J
                                  • 9535
                                  The feedback is a winding off the transformer, (T1B) which connects to R4, and D1 diode to supply the run vcc for the ic. Your component designations will be different but the circuit should be the same.
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 940
                                    Ok, so I checked every component on the back of the board and didn't find anything suspicous, except for a T4 diode that was in parallel with a 100 ohm resistor, so I removed it and it tested good.
                                    Took out the little transformer and the output seems shorted as can be seen in the photos with my blue ring tester compared to a good coil. Also took a closup of the inside for your info.
                                    I guess this means I will have to retire this power supply and keep it for parts with the exception of the transformer, right?
                                    • lotas
                                      • Jan 2016
                                      • 4601
                                      • Russia
                                      You are not diagnosing correctly, you need to check not the output winding, but the power winding, where the output is from the mosfet.
                                      • R_J
                                        • 9535
                                        I doubt the transformer is bad, Check the resistance of the windings, if they are not open I suspect the transformer is ok. Did you check the primary and feedback windings with your ringer?
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
