DirecTiVo Power Supply Caps
  • moonchilddave
    • Sep 2010
    New here...
    I've got a few DirecTV Phillips DSR704 TiVo's that have failing power supplies, so I'm at the point of replacing all the electrolytic caps - but am not sure what to order for replacements. Below are the original supply values (all are 105deg):
    C9 - 47uf / 50V (Teapo SEK)
    C14 - 2200uf / 10V (Ltec LZG)
    C15 / C20 /C42 - 470uf / 10V (Ltec LZG)
    C17 - 2200uf / 10V (Ltec LZG)
    C18 - 2200uf / 16V (Teapo SC)
    C23 - 470uf / 50V (Ltec LZG)
    C26 - 47uf / 63V (Teapo SEK)
    C27 - 1uf / 50V (Teapo SEK)
    C29 - 10uf / 50V (Teapo SEK)
    C34 / C35 - 2.2uf / 50V (Ltec) - unknown series (tiny black cap with gold banding and lettering)
    Any help or pointers would be greatly appreciated!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: DirecTiVo Power Supply Caps
    PCBONEZ's instructions on how to "match" the right series of caps.
    https://www.badcaps.net/forum/showpo...47&postcount=3
    If Panasonic caps meet your requirements, follow PlainBill's instructions at
    https://www.badcaps.net/forum/showpo...33&postcount=2
    --- begin sig file ---
    --- end sig file ---
      • 31304
      you need to add the diameter of each cap if they are tight together.
      • moonchilddave
        • Sep 2010
        I was going to go back and add dimensions but it was past the time to edit. Unless I'm missing something it looks like the Nichicon PW series caps will work for all of them (someone correct me if I'm wrong). Although not sure about C34/35 as I'm not sure what series those are to begin with.
        The ones that I've selected that seem to be a best match:
        C9 - 47uf / 50V (Teapo SEK) - 6mm x 12mm : UPW1H470MED
        C14 - 2200uf / 10V (Ltec LZG) - 13mm x 20mm : UPW1A222MHD
        C15 / C20 / C42 - 470uf / 10V (Ltec LZG) - 8mm x 12mm : UPW1A471MPD
        C17 - 2200uf / 10V (Ltec LZG) - 10mm x 30mm : UPW1A222MPD6
        C18 - 2200uf / 16V (Teapo SC) - 13mm x 25mm : UPW1C222MHD
        C23 - 470uf / 25V (Ltec LZG) - 10mm x 16mm : UPW1E471MPD
        C26 - 47uf / 63V (Teapo SEK) - 8mm x 12mm : UPW1J470MPD
        C27 - 1uf / 50V (Teapo SEK) - 5mm x 12mm : UPW1H010MDD
        C29 - 10uf / 50V (Teapo SEK) - 5mm x 12mm : UPW1H100MDD1TD
        C34/35 don't have a series on the cap, but I'm guessing since all the Ltec caps in the original supply are LZG series that the PW series would be fine for them as well.
        C34 / C35 - 2.2uf / 50V (Ltec) - 4mm x 6mm : UPW1H2R2MDD
        These are a bit bigger but where they are located, should have plenty of room.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
