Help finding replacement diode
  • Storyteller12
    • Jun 2020
    • 624
    I am ordering parts from Mouser electronics and need help finding a replacement diode.
    Attached are pics of the good diode with readings.
    Thanks in advance
  • petehall347
    • Jan 2015
    • 4424
    • United Kingdom
    Re: Help finding replacement diode
    they are marked as zeners .
      • 30950
      it's a zener diode, test it in the A & K position.
      • Storyteller12
        • Jun 2020
        • 624
        Thanks for the help
          • 30950
          so now you know, it's a 15 or 16v zener diode,
          from the size it's probably rated at 400 or 500mW
          • Storyteller12
            • Jun 2020
            • 624
            Thank you very much. I think 16v as that what the relay from the filter board is rated and that connect to this board.
            Can you confirm if this zener diode will work as a suitable replacement from mouser.
            https://www.mouser.com/ProductDetail...2F2sTlqw%3D%3D
            Appreciate it
              • 30950
              looks good - you need to check the length of the original against them though.
              and at those prices - obviously you want 10 of them
              • petehall347
                • Jan 2015
                • 4424
                • United Kingdom
                why replace if seemingly good ?
                • Storyteller12
                  • Jun 2020
                  • 624
                  There not good. I have 2 identical boards on an induction cooktop. 1 blew up and I'm using the good board to find values of parts for the bad one
                  • Storyteller12
                    • Jun 2020
                    • 624
                    Thank you stj for your expertise.
                    • petehall347
                      • Jan 2015
                      • 4424
                      • United Kingdom
                      good plan . carry on as you were .
