I’m looking for MBP A1278 schematics
  • Guest
    Hi everyone, I'm looking for MBP A1278 schematics.
    I have 2008 A1278 Macbook Pro with 2.4GHz C2D and Nvidia 9400M.
    Motherboard EMC: 2254
    I'm looking for schematics, because the Macbook doesn't work so I want to find and test the onewire circuit.
    I couldn't find schematics for motherboard with same emc on this forum, if there is a thread with schematics for this motherboard that I overlooked, please reply with link.
  • Rezendes
    Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
    by Rezendes
    Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
    I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
    The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
    05-10-2024, 02:18 PM
  • CG_Dionysos
    MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
    by CG_Dionysos
    I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
    • Model: A1707
    • 15-inch, Mid 2017
    • 3.1 GHz Core i7
    • 16 GB RAM
    • Radeon Pro 560
    • 1 TB SSD
    • Board number: 820-00928-A
    I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
    Thanks in advance!
    Greetings from Germany...
    09-16-2025, 06:43 AM
  • Adogabriel100
    Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
    by Adogabriel100
    Hey! This is a A1278 macbook 2011.
    Problem: Not turning on / No green light
    Im using by3200s charger.
    Voltajes:
    PPBUS_G3H = 12.26v
    SMC_RESET_L = 3.3v
    PP3V42_G3H = 3.42v
    U7000 =
    Pin 1 CHGR_AGATE = 0v
    Pin 2 CHRG_DCIN = 19v
    Pin 3 CHRG_ACIN = 4.6v
    Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
    Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
    Pin 12 PP3V42_G3H = 3.42v
    Pin 13 CHRG_RST_L = 3.3V
    Pin 14 SMC_BC_ACOK = 0.8V
    Pin 19 PP5V1_CHRG_VDD = 5.05V
    Pin 20 PP5V1_CHRG_VDDP = 5.03V...
    04-01-2024, 01:02 PM
  • pcbmaniac
    MacBook A1278 (3115) No PPBUS_G3H Issue
    by pcbmaniac
    Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
    I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
    1. U7000 Measurements:
      • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
    2. Resistors:
      • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
    Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
    • If I also decide to replace the SMC, do I need to order it pre-programmed,
    12-02-2024, 04:12 PM
  • sizar00740
    macbook pro 13 inch a1278 820-2879
    by sizar00740
    please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
    07-30-2025, 10:21 AM
