HP 15-ck001nw DAG77MB18C0 rev. C
  • TecnicaNTT
    • Feb 2015
    • 72
    • Portugal
    Does anyone have the boardview for this motherboard?
  • TecnicaNTT
    • Feb 2015
    • 72
    • Portugal
    DAG77MB18C0 Boardview
    Hi comunity,
    I am looking for the boardview for this motherboard: DAG77MB18C0
    It's from an HP 15-CK002NP.
    The EC chip ITE8987E is getting hot, I already replaced it and the new one is still getting hot.
    I think I found a short to ground on a rail I cannot identify, I think it is the 3.3V rail but I need the boardview to be sure where it goes.
    Thank you!
    • adigrf
      • Jun 2025
      • 5
      • romania
      Hello! is there an update here ? I would also need this schematic for DAG77MB18C0 rev c
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • bimole
        Weird behavior on 3.3V rail of a CORSAIR CX600
        by bimole
        A colleague gave me an apparently ill CORSAIR CX600.
        He told me that he heard a banging noise, and smelt the magic smoke.
        After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
        I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
        It's another story on the 3.3V rail...
        I have some devices to test deeply PSUs (scope, AC source, electronic load)...
        02-13-2025, 04:49 AM
      • Maciej Skoczylas
        GV-N3060GAMING OC-12GD - boardview for specific revision
        by Maciej Skoczylas
        I have problem with my graphic card GV-N3060GAMING OC-12GD.
        2 smd elements are missing.
        I've already bought a boardview but it's not complete - that specific area is not attached. I tried with different similar models but without success.
        This is my PCB
        And this is screen of boardview
        As you see those missing capacitors or resistors are not on boardview.
        Also i compared every single transistor from boardview to real card and everything is related.
        It seems that this one is like extra.
        Could anyone...
        08-09-2025, 10:26 AM
      • madan1
        DALI SUB E-12F class D, fluctuating power rail
        by madan1
        Good day everyone.
        I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
        The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
        The normal value of the positive and negative power rails is +/- 43V.
        The positive rail stays...
        10-15-2025, 10:33 AM
