I'm stumped A505 S1990 has kicked my donkey
  • sammonselectronics
    • Sep 2021
    • 5
    I opened a working laptop and reseated the key board ribbon because a few keys not working..
    Mistake!!!!! Now the unit is Dead grave yard dead!
    No lites fan boot.... Nothing
    20 volts to mother board
    I need a service manual
    Does anybody have any idea where l could obtain a copy?
    • 20578
    Re: I'm stumped A505 S1990 has kicked my donkey
    Post the full laptop model number ,such as E305-S1990 , A505-?????
    Post the motherboard part number,it will be silkscreened in white
    Post if you want a Service manual , schematic or both
    Did you reseat the cable with the battery or charger attached
    • soler88
      Samsung UN46H5203 backlight issue - stumped
      by soler88
      I am trying to fix this tv that has image and sound but no backlight. Replaced all led strips and each strip turns on using a led tester but do not get any backlight when the tv turns on.
      I disconnected the main board from the PS but still no backlight.
      Looking at previous threads, nothing is jumping out at me and I'm stumped.
      Here are the voltage measurements:
      ON STATE
      CNM803 on PSU from Main
      Pin 1 A13v - 13.09v
      Pin 2 OD_UD - 3.3v
      Pin 3 A13v - 13.09v
      Pin 4 BLU_PWM - 1.6v
      Pin 5 A13v...
      10-09-2024, 07:28 AM
    • EazyBone
      Hisense H6750G stumped on this
      by EazyBone
      Picked up another free one. The original owner replaced power board to try and fix them gave up gave to me
      Problem: Red led standby light blinks once every 5 seconds repeatedly for ever.power button does nothing. Nothing turns on.
      PSU, 12v are all 12v to main, 18v are all 16.6 stby is 2.6
      Disconnect main and 12v is 10.5 and 18v become 14.4.
      This is the same for BOTH psus.
      Backlight tester turns on backlights at 105v each strand and work properly.
      I cannot get ANY voltage to backlights on either power supply. They remain...
      08-30-2023, 01:25 PM
    • japlytic
      Donkey Kong Junior arcade DMA controller choice
      by japlytic
      This is about a component in a computer system being a DMA controller.
      Interestingly in a circuit diagram for the Nintendo arcade game Donkey Kong Junior from 1982, even though it has a second-source Zilog Z80 compatible CPU, the DMA controller is an Intel type (8257) instead of a Zilog type.
      My theory is that at the time, even though there was domestic second source manufacture for the 8257 but not (possibly) for the Zilog type DMA controller and that Nintendo (and a number of others) wanted to be loyal to their country by trying to only source components from Japanese ...
      12-01-2022, 01:39 AM
    • Mark R
      Marantz Model 120 Tuner Craziness I am Stumped!
      by Mark R
      My Marantz 120 Tuner stopped receiving Stereo signals. It works fine other then Stereo. I have a fully loaded shop here with all test equipment except and RF signal Generator.
      I get great reception on FM so I have used that signal troubleshoot. I have been all over the MPX board and replaced all caps. Also the entire power supply caps were replaced.
      All Voltages on the MPX board are good... all Transistors Good...All Diodes Good and other components.
      The stereo lamp is good as I powered it up and it lights. The signal flow to that lamp is unbelievably...
      10-20-2023, 01:25 PM
    • TvtechNue-b
      LG 55UH615A Half Screen Dark, Replaced LED's & Power Board, Completely Stumped
      by TvtechNue-b
      I have this LG 55UH615A with half screen is Dark. This is an edge lit TV with 2 small LED strips that run along the bottom of the TV. When I got it, only one half of it was lit. Also, there was a buzzing noise coming from the power board. I ordered new LED strips and also a replacement power board. Installed both and I'm still getting the same problem. When I test the wires going to both LED strips, Im getting solid, non fluctuating voltages from the power board and also at the connectors plugged into the LED strips. I tried to rule out if possibly the new LED strip on the dark side was bad. I...
      12-01-2020, 06:30 PM
