Asis x412u
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Asis x412u
    I need schematic for this model ASUS X412U, I need to find the on and off switch pin on keyboard connector please, the problem is pressing the power button on keyboard not turning on and no response, I need to find the exact switching pin on the keyboard connector, because i chech there is a lot of 3.3v,laptop is working automatically without battery
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Asis x412u
    anyone has schematic for this please
    • corrize
      Where to find a very small fpc connector 0.3mm between 2 pins ?
      by corrize
      Hello, I search this connector (oxydated).
      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
      Do you know how to find this connector please ? What is the exact name for find it ?
      08-06-2024, 05:25 PM
    • Tomylee
      No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
      by Tomylee
      Sorry for the person who’s going to read all this !
      I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
      While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
      During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
      07-11-2025, 11:52 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • 5mall5nail5
      Help identifying connector for ASUS 4090 Strix RGB LED connector
      by 5mall5nail5
      Hi All -
      I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
      Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
      05-04-2025, 07:47 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
