Hp tpn-q208 dag7blmb8d0 rev d
  • vikaspowar
    • Jul 2016
    • 5
    • india
    Pls...provide schemetic and boardview
    part number is dag7blmb8d0
  • josel
    • Apr 2021
    • 11
    Re: Hp tpn-q208 dag7blmb8d0 rev d
    does anyone have it?
    • reassor
      • Apr 2021
      • 176
      • Poland
      looking too
      • mon2
        • Dec 2019
        • 14544
        Could this work ?
        • sebulica
          Beginner
          • Mar 2014
          • 50
          • Romania
          Originally posted by mon2
          Could this work ?
          Yeah.Can you post it ? thanks
          • Dcaub
            • May 2022
            • 6
            • BE
            searching Schematic HP DAG7BLMB8D0 Rev. D
            I there anyone that can provide me a schematic for HP 15-CS3034NB mainboard model nr : DAG7BLMB8D0 Rev. D
            many thanks.
            Dca
            • jaglion19
              • Oct 2017
              • 102
              • TURKEY
              DAG7BLMB8D0 need schematic
              Good luck to everyone guys, I have such a motherboard, when I give 3v to the start button, while the adapter is plugged in, the device turns on, there is 0.90v at the place with the trigger button, 3v should come, can anyone help with the diagram or the way?
              • doesntmind
                • Feb 2014
                • 61
                • usa
                Could this work ?
                Lol you took a screen shot of the file, just what we needed!
                • FORMIDABLE
                  • Apr 2023
                  • 3
                  • Benin
                  Hello please I need the schematic of HP Pavillon dag7blmb8d0 rev d
                  • manol278
                    • Nov 2017
                    • 41
                    • greece
                    Schematic or boardview for HP 15-CS DAG7BLMB8D0 Rev. D ??????
                    • Charles24
                      • Dec 2022
                      • 9
                      • Sri Lanka
                      Can anyone post me the model of the charger IC used in this laptop DAG7BLMB8D0 . I received this laptop for repair which was already undertaken for repair and the persin removed charger IC and did not replace, I need the model number so I can replace it
                      • milui
                        • Apr 2013
                        • 16
                        • Napoli
Name:	Immagine WhatsApp 2024-04-25 ore 16.54.54_039f2b5b.jpg
                        Intersil 88739b
                        • Charles24
                          • Dec 2022
                          • 9
                          • Sri Lanka
                          Intersil 88739b
                          Thank you so much bro
                          • Stil86
                            • Jun 2013
                            • 15
                            • Italy
                            Hi there, can someone please tell me the value of the three capacitor higlighted in the picture ?
                            • edugimeno
                              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                              by edugimeno
                              Hi There!
                              I'm trying to help my friend who owns a restaurant be just bought.
                              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                              It's stuck using, I guess, the 2 sided tape that comes with the strip
                              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                              09-05-2024, 09:34 AM
                            • G-Sting
                              iPad Pro A1876 SHORT Part Identify Help Needed
                              by G-Sting
                              So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                              So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                              i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                              SO My main concern is what part should i order what should i search the name for ?
                              on Ipad...
                              05-15-2025, 09:30 AM
                            • Yanleb
                              Panasonic part number in service manuals
                              by Yanleb
                              In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                              This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                              For an example, look at the attached PDF.
                              Do you have a way to cross reference the Panasonic part number with the actual part number?
                              Thanks....
                              07-03-2023, 08:16 PM
                            • FreakyMex
                              Trouble to identify part (Lunii screen) for replacement
                              by FreakyMex
                              Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                              I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                              02-17-2025, 01:16 AM
                            • esinior
                              Smd code to part number
                              by esinior
                              Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                              I've attached pics of this part
                              Thanks...
                              08-20-2024, 02:50 AM
