Dell 14 3474 5437 Essentials Oak 14 DOE40_12314
    • 20855
    Dell 14 3474 5437 Essentials Oak 14 DOE40_12314 Schematic + Boardview
    The boardviews will open with BoardViewer .
  • Bonzas
    • 471
    • Indonesia
    Re: Dell 14 3474 5437 Essentials Oak 14 DOE40_12314
    Thank you very much
    • goujibing
      • Feb 2022
      • 中国
      Thank you very much
      • ymy93423
        • Jul 2022
        • 3
        • 中国
        Think you!
        • redman13
          • Aug 2016
          • 66
          • bangkok
          Thang you
          • swastik201
            • Aug 2019
            • 5
            • india
            thanks a lot
            • Doniciputat
              • Aug 2022
              • 109
              • Indonesia
              Originally posted by smdflea
              dell 14 3474 5437 essentials oak 14 doe40_12314 schematic + boardview
              the boardviews will open with boardviewer .
              thanks master
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • F R 2568
                Dell Latitude 5420 does not start (no post) need help to find the reason why
                by F R 2568
                Hello all,
                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                If the laptop is only connected to the AC adapter (battery removed):
                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                The power/battery...
                01-08-2025, 05:45 AM
              • diamon
                Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                by diamon
                I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                Pictures of these boards:
                Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                Dell...
                02-28-2024, 12:51 PM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
              • OntarioTL
                Dell 5410 greyed out BT
                by OntarioTL
                Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                Dell Lattitude 5410
                Service Tag...
                07-25-2025, 01:28 PM
