Dell 14 3474 5437 Essentials Oak 14 DOE40_12314
    • 21880
    Dell 14 3474 5437 Essentials Oak 14 DOE40_12314 Schematic + Boardview
    The boardviews will open with BoardViewer .
  • Bonzas
    • 472
    • Indonesia
    Re: Dell 14 3474 5437 Essentials Oak 14 DOE40_12314
    Thank you very much
    • goujibing
      • Feb 2022
      • 中国
      Thank you very much
      • ymy93423
        • Jul 2022
        • 中国
        Think you!
        • redman13
          • Aug 2016
          • 66
          • bangkok
          Thang you
          • swastik201
            • Aug 2019
            • 6
            • india
            thanks a lot
            • Doniciputat
              • Aug 2022
              • 111
              • Indonesia
              Originally posted by smdflea
              dell 14 3474 5437 essentials oak 14 doe40_12314 schematic + boardview
              the boardviews will open with boardviewer .
              thanks master
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
                Dell Thunderbolt Firmware
                by SMDFlea
                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                The SKU is in brackets (****)
                EDIT: NVM65...
                01-26-2025, 06:22 AM
              • F R 2568
                Dell Latitude 5420 does not start (no post) need help to find the reason why
                by F R 2568
                Hello all,
                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                If the laptop is only connected to the AC adapter (battery removed):
                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                The power/battery...
                01-08-2025, 05:45 AM
