ASUS GL553VD MAIN BOARD REV:2.0 - Boardview
  • Sephir0th
    • Oct 2020
    • 1246
    Kind regards!
    FairRepair on YouTube
  • MrEmiriv
    • Mar 2016
    • 14
    • Argentina
    Re: ASUS GL553VD MAIN BOARD REV:2.0 - Boardview
    Thanks! this made my job much easier
    • rizky
      • Jun 2021
      • 7
      • indonesia
      Originally posted by Sephir0th
      Kind regards!
      thanks sir
      • dreams28
        • Mar 2016
        • 22
        • turkey
        thank you ..
        • luisfm2
          • Jan 2015
          • 51
          • Portugal
          Thank you..
          • siroos_tz
            • Feb 2014
            • 119
            • the UK
            Kind regards!
            Thank you very much.
            • Fadda88
              • May 2017
              • 12
              • Italy
              Thank you
              • tomodachi
                • Apr 2012
                • 593
                • Turkey
                Thanks a lot
                • HA3BA
                  • Jan 2023
                  • Ukraine
                  Thank you very much!
                  • guizmo1967
                    • Sep 2022
                    • 75
                    Asus GL553VD Schematic needed !
                    Anyone has this schematic ??
                    Thank you if you do !
                    • kusal
                      • Jul 2021
                      • 27
                      • Sri Lanka
                      thankz
                      • lione
                        • Dec 2017
                        • 7
                        • Iran
                        thank you
                        • ettaki
                          • May 2018
                          • 3
                          • canada
                          thanks bro
                          • gensan
                            • Nov 2015
                            • 3
                            • Ukraine
                            Thank you
                            • dhanasiri.bac
                              • Dec 2012
                              • sri lanka
                              THANKS BOSS
                              • louiloiiuio
                                • Jul 2024
                                • france
                                Thanks you very much
                                • enes_rs
                                  • Aug 2024
                                  • brussel
                                  thank you ! Can i ask you for help if its possible, i have Asus gl553vd and the issue was when i shutdown the laptop then cannot turn it ON need to wait 20 30min.. and i did mistake to update bios from official website asus.. i dont know where is the issue but later i bought the bios chip installed again bios firmware but not working... in the end i found the same laptop. SO my plan is to check one by one hte parts of mainboard that owrking where can be the issue. The problem is that i dont know to read thsi digram
                                  • Mateo Rosas
                                    • Mar 2025
                                    • 3
                                    • M
                                    • Dani_2024
                                      by Dani_2024
                                      10-28-2024, 05:06 PM
                                    • jb_Bak
                                      by jb_Bak
                                      CN6401
                                      Pin 01 NC
                                      Pin 02 NC
                                      Pin 03 "BL_ON": 0V
                                      Pin 04 "N/C"
                                      Pin 05 "STBY 3.3V": 3.5V
                                      Pin 06 "GND": N/C
                                      Pin 07 "AC_OFF"...
                                      09-27-2021, 04:52 PM
                                    • JDC
                                      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                      by JDC
                                      ONN 100012588
                                      Issue: No Power, Then Rebooting After Main Board Change
                                      Short answer: replace main board and power board
                                      Technical answer: replace main board and Q306 & Q307 on power board.
                                      Long answer:
                                      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                      07-15-2022, 07:39 AM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • cheeky2
                                      by cheeky2
                                      05-25-2024, 03:27 AM
