A2159 MacBook Pro (13-inch, 2019) 820-01598-06
  • zribit
    • Aug 2023
    • 15
    • France
    #61
    Re: A2159 MacBook Pro (13-inch, 2019) 820-01598-06
    thank you and congratulations for the work
    • seka4a
      • Oct 2021
      • bulgaria
      #62
      Thanks to everyone for your shared files
      • Sonorstick
        • Jan 2022
        • España
        #63
        Thank you very much
        • mobilesolution
          • Jul 2020
          • 17
          • india
          #64
          • Dwitty
            • Jul 2021
            • 21
            • Earth
            #65
            Thx!
            • jesi
              • Jul 2013
              • 74
              • uk
              #66
              nice one thank 🎉🎉🎉🎉🎉🎉🎉🎉🎉
              • dariowap
                • Oct 2020
                • Italia
                #67
                Tankkksssss
                • kochsony
                  • Apr 2023
                  • Berlins
                  #68
                  thank you 😘
                  • SandSpark
                    • Feb 2025
                    Thank You!
                    • Felipe_Serra_83
                      • Nov 2023
                      • 25
                      • Chile
                      #70
                      Thank you!
                      • bouch
                        unlock macbook air A1932 2019
                        by bouch
                        hi
                        i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                        i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                        i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                        have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                        I need help or information?
                        Does anyone have the minat2 activator 1.4 software?
                        Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                        Thank yo...
                        03-12-2025, 10:14 AM
                      • Eniaro
                        MacBook Pro 2019 A2159 (2-port) wont boot
                        by Eniaro
                        Trackpad clicks.
                        Plugging in a genuine USB-C charger and any other charger = 20V and charges all the way.
                        Plugging in a Dell USB-C dock or monitor causes the voltage to cycle endlessly between 5V and 19V
                        The Caps Lock button doesn't illuminate.
                        Holding the power button (fingerprint scanner) for 10 seconds stops the trackpad clicking temporarily, but it starts clicking again after 3 seconds.
                        If I open the lid slightly, the trackpad stops clicking (it seems to be detecting the lid opening/closing).
                        The keyboard backlight...
                        11-27-2024, 04:25 PM
                      • kuba2102
                        MacBook Pro 2019 A2159 Replacing SSD does it need programming?
                        by kuba2102
                        Hi. I suspect the SSD has failed on this machine. I couldn't find answers googling it hence my question. Can you just take and replace SSD from another mac 2019 or it need to be programmed with serial numbers etc? Also eg. if my macbook is 128GB and using only one slot/bank for the SSD and another slot/bank is not being used (empty), can you remove the SSD from slot 1 and put it into slot 2, would it work? I know for a fact that those SSD are set in RAID partitions so if arranged in wrong order it's not going to work, but I'm curious if it needs programming also if the SSD can be soldered onto...
                        09-01-2022, 12:58 PM
                      • thuygsm
                        Macbook pro A2159 EMC3301 no image, no CapsLocklight, only USB activity
                        by thuygsm
                        Hello! Please help with a strange disease that I have never encountered before.
                        At first I got the following status:
                        MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
                        - no signs of rust, or spilled water
                        - CPU gets hot, fan still spins, no Capslocks light
                        then I cleaned it and I got the following video:
                        - Cannot install software, and after a while I get a red screen and the whole thing freezes
                        Macbook Pro A2159 / Bệnh lạ
                        07-28-2025, 11:35 AM
                      • kenzo2
                        Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                        by kenzo2
                        I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                        I need dump file MACBOOK PRO A2159
                        TSB4232(256)
                        TSB4229(256)
                        Thanks​
                        01-11-2025, 04:18 AM
