Macbook pro A2159 EMC3301 no image, no CapsLocklight, only USB activity
  • thuygsm
    Nguyen Van Thuy
    • Jan 2023
    • 17
    • vietnam
    Hello! Please help with a strange disease that I have never encountered before.
    At first I got the following status:
    MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
    - no signs of rust, or spilled water
    - CPU gets hot, fan still spins, no Capslocks light
    then I cleaned it and I got the following video:
    - Cannot install software, and after a while I get a red screen and the whole thing freezes
    Macbook Pro A2159 / Bệnh lạ
  • Ugur87
    MacBook Air M4 A3240 Brand New Water Damage no Image
    by Ugur87
    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
    08-28-2025, 01:09 PM
  • kenzo2
    Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
    by kenzo2
    I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
    I need dump file MACBOOK PRO A2159
    TSB4232(256)
    TSB4229(256)
    Thanks​
    01-11-2025, 04:18 AM
  • Madoy104
    Macbook Pro A1989 - No image, working fine with external monitor
    by Madoy104
    I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
    08-15-2024, 10:01 AM
  • mferna14
    Password removal on MacBook Pro A2159
    by mferna14
    Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
    05-13-2025, 04:16 PM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
