MacBook Pro 2019 A2159 Replacing SSD does it need programming?
  • kuba2102
    • Jan 2020
    • 45
    • Scotland
    Hi. I suspect the SSD has failed on this machine. I couldn't find answers googling it hence my question. Can you just take and replace SSD from another mac 2019 or it need to be programmed with serial numbers etc? Also eg. if my macbook is 128GB and using only one slot/bank for the SSD and another slot/bank is not being used (empty), can you remove the SSD from slot 1 and put it into slot 2, would it work? I know for a fact that those SSD are set in RAID partitions so if arranged in wrong order it's not going to work, but I'm curious if it needs programming also if the SSD can be soldered onto unused slot 2 leaving the slot 1 empty. Thanks
  • Slam!
    • Nov 2019
    • usa
    Re: MacBook Pro 2019 A2159 Replacing SSD does it need programming?
    My understanding is the T2 is "married" to the SSD. Unknown what data exactly is relayed between the two but have heard it is all encrypted. Haven't heard of a successful SSD swap as yet, if you do have success let us know.
    • piernov
      • Jan 2016
      • 4439
      • France
      SSD ICs can be replaced from same model donor board (with similar storage configuration) or reconfigured with JC P13, then T2 DFU restore is needed. Of course data cannot be saved.
      • sidestep
        • Украина
        can i install 512 or 1tb nands to board which was 128 from factory? i have p13
        • bouch
          unlock macbook air A1932 2019
          by bouch
          hi
          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
          I need help or information?
          Does anyone have the minat2 activator 1.4 software?
          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
          Thank yo...
          03-12-2025, 10:14 AM
        • Eniaro
          MacBook Pro 2019 A2159 (2-port) wont boot
          by Eniaro
          Trackpad clicks.
          Plugging in a genuine USB-C charger and any other charger = 20V and charges all the way.
          Plugging in a Dell USB-C dock or monitor causes the voltage to cycle endlessly between 5V and 19V
          The Caps Lock button doesn't illuminate.
          Holding the power button (fingerprint scanner) for 10 seconds stops the trackpad clicking temporarily, but it starts clicking again after 3 seconds.
          If I open the lid slightly, the trackpad stops clicking (it seems to be detecting the lid opening/closing).
          The keyboard backlight...
          11-27-2024, 04:25 PM
        • thuygsm
          Macbook pro A2159 EMC3301 no image, no CapsLocklight, only USB activity
          by thuygsm
          Hello! Please help with a strange disease that I have never encountered before.
          At first I got the following status:
          MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
          - no signs of rust, or spilled water
          - CPU gets hot, fan still spins, no Capslocks light
          then I cleaned it and I got the following video:
          - Cannot install software, and after a while I get a red screen and the whole thing freezes
          Macbook Pro A2159 / Bệnh lạ
          07-28-2025, 11:35 AM
        • kenzo2
          Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
          by kenzo2
          I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
          I need dump file MACBOOK PRO A2159
          TSB4232(256)
          TSB4229(256)
          Thanks​
          01-11-2025, 04:18 AM
        • alfredodinolfo
          MacBook Pro 2019 (A1990)
          by alfredodinolfo
          mb code:820-01827-A;
          sn:C02Z349ALVDR;
          i9 32GB Ram 1TB
          Hi, I found short on one of 6 black nand (total 1TB).
          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
          macbook with A2141 configuration run on recovery but don't complete it.​
          anyone can help me?
          05-26-2025, 09:27 AM
