HP DV6-DV7 Quanta LX6_7 looking for .brd
  • afourtrackmind
    • Nov 2013
    • 10
    • Cananda
    Anyone have HP dv6_dv7 Quanta LX6_7 boardview?
  • afourtrackmind
    • Nov 2013
    • 10
    • Cananda
    Re: HP DV6-DV7 Quanta LX6_7 looking for .brd
    HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2
    • piernov
      • Jan 2016
      • 4439
      • France
      • pcnetwork
        • Jan 2021
        • 30
        • Venezuela
        Thanks for the help
        • lpraderi
          Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
          by lpraderi
          Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
          In some cases to use LVDS screen PCB use converter IC RTD2132/6
          Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
          at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
          Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
          11-25-2023, 09:31 AM
        • afourtrackmind
          HP dv6 Power Issues HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2
          by afourtrackmind
          *Same issue i believe. i posted in the wrong place, found this incomplete so I suppose i work from here. I now have the board view from this thread and will post my progress*
          Default HP dv6 Power Issues HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2
          I have a weird issue. Just typing it out may help me move forward on this.
          Lets go over the details
          DV6 HP laptop. No power under normal conditions. No boot direct from PSU. PSU provides light when batt is connected but does not charge batt. Computer boots and operates from battery.
          09-25-2019, 03:59 PM
        • Francisco.s
          Quanta N76 power-on issue.
          by Francisco.s
          Hello, I'm trying to repair an HP 27 Quanta N76 (DA0N76MB6E0 Rev E).
          I only get 3.3V, 5V, and 1.05V; no other voltages.
          I tried the BIOS and changed the KBC. The KBC self-programmed upon power-up after changing it.
          The VR-On is missing for NCP81220, but 1.2V is also missing for DDR4, so 1P2V_PWRGD is low. SUSON or DDR_VTT_EN are not present on the DDR4 voltage regulator (RT8231BGQW). It seems the KBC isn't triggering these signals.
          I'm using the Quanta N91 schematic, but there are too many changes that make it nearly impossible to measure signal...
          07-14-2025, 02:20 PM
        • Maxmad
          HP Omen 17t-ck100 Quanta G3LB DAG3LBMBCD0 schematic
          by Maxmad
          Anyone has schematic for this laptop board? HP Omen 17-ck1000 Quanta G3LB DAG3LBMBCD0...
          10-19-2025, 03:00 PM
        • supermattch
          Quanta DA0P5HMB8F1 rev. F
          by supermattch
          I need the schematic and boardview for the Quanta DA0P5HMB8F1 revision F. The laptop is a HP 15dy-2021nr. I keep finding similar boardviews but not this particular one. The components are in different places than those similar ones. Thank you.
          09-14-2025, 03:43 AM
