HP dv6 Power Issues HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2
  • afourtrackmind
    • Nov 2013
    • 10
    • Cananda
    *Same issue i believe. i posted in the wrong place, found this incomplete so I suppose i work from here. I now have the board view from this thread and will post my progress*
    Default HP dv6 Power Issues HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2
    I have a weird issue. Just typing it out may help me move forward on this.
    Lets go over the details
    DV6 HP laptop. No power under normal conditions. No boot direct from PSU. PSU provides light when batt is connected but does not charge batt. Computer boots and operates from battery.
    Power supply is providing the spec'd voltage. Not sure under load but my gut and experience don't suspect the PSU.
    The DC socket and connector appear in good condition, voltage is present on the board connector.
    With the battery disconnected and PSU connected there is no sign of life at all.
    Connect battery and the charge light/indicator goes red(ish). The battery does not charge though. The computer will only boot for as long as the battery has power. I will verify in a few mins by charging the battery on my benchtop PSU.
    I believe the issue is in the power section on the motherboard. I have a block diagram schematic, of which im not entirely comfortable with, I cant figure out how to decipher the abbreviations just yet. I am familiar and comfortable with older schematics and Im sure with a little more concentration ill eek my way through them. Ive just been looking at them for a little while and having trouble following the digram through to the real life circuit. I have been trying to find a boardview file but no luck, something close but not the same model.
    HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A is the exact model i have. If anyone has the borad view file do you mind helping me out?
    Has anyone seen a fault like this before? Anybody recognize this or similar behaviour?
    I've just done a ton of work for this customer and it failed like this an hour into me returning his unit to him. I'm already in for waaaay to many hours on this.
    Any help is greatly appreciated.
    further details; PSU indicator light turns on for 1 second before turning red(is
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: HP dv6 Power Issues HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2
    This is a different laptop with a different board (there are a lot of different dv6, don't get confused), so I moved the post out of the other thread (still reachable at https://www.badcaps.net/forum/showthread.php?t=63799 ).
    For schematics/boardviews, please ask under the "Schematic Requests ONLY!" subforum. EDIT: ah, you did already, just saw that.
    For the actual issue, starting from the same point as the other thread — measuring voltage on the DC-in connector — could be a good idea though. Measure without battery.
    On the schematics this will be CN15.
    Then you can measure the voltage on the main power rail +VIN, on PR155 for example.
    • lpraderi
      Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
      by lpraderi
      Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
      In some cases to use LVDS screen PCB use converter IC RTD2132/6
      Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
      at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
      Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
      11-25-2023, 09:31 AM
    • fixme2024
      Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
      by fixme2024
      Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
      Here, I have attached a document...
      02-14-2024, 09:24 PM
    • Francisco.s
      Quanta N76 power-on issue.
      by Francisco.s
      Hello, I'm trying to repair an HP 27 Quanta N76 (DA0N76MB6E0 Rev E).
      I only get 3.3V, 5V, and 1.05V; no other voltages.
      I tried the BIOS and changed the KBC. The KBC self-programmed upon power-up after changing it.
      The VR-On is missing for NCP81220, but 1.2V is also missing for DDR4, so 1P2V_PWRGD is low. SUSON or DDR_VTT_EN are not present on the DDR4 voltage regulator (RT8231BGQW). It seems the KBC isn't triggering these signals.
      I'm using the Quanta N91 schematic, but there are too many changes that make it nearly impossible to measure signal...
      07-14-2025, 02:20 PM
    • Maxmad
      HP Omen 17t-ck100 Quanta G3LB DAG3LBMBCD0 schematic
      by Maxmad
      Anyone has schematic for this laptop board? HP Omen 17-ck1000 Quanta G3LB DAG3LBMBCD0...
      10-19-2025, 03:00 PM
    • supermattch
      Quanta DA0P5HMB8F1 rev. F
      by supermattch
      I need the schematic and boardview for the Quanta DA0P5HMB8F1 revision F. The laptop is a HP 15dy-2021nr. I keep finding similar boardviews but not this particular one. The components are in different places than those similar ones. Thank you.
      09-14-2025, 03:43 AM
