Da0zhpmb8f0 rev:f schematİc
  • drewpcfix
    • Feb 2021
    • 13
    • philippines
    Re: Da0zhpmb8f0 rev:f schematİc
    I need boardview for this board anyone thanks
    • angourie
      • Aug 2019
      • 5
      • Greece
      Thanks!
      • dt4brus
        • Jun 2019
        • Croatia
        I need boardview for this board anyone thanks.
        Or if someone has done modification for so-dimm only(just removed memory chips)
        Any help would be great
        • zhekamail
          • Jun 2019
          • 6
          • Russia
          Originally posted by peste
          try..
          • rheyntau
            • Feb 2021
            • 29
            • philippines
            Is der available board view for this model?
            • siroos_tz
              • Feb 2014
              • 121
              • the UK
              #26
              try..
              Thanks a lot
              • satheesh123
                • Oct 2016
                • 22
                • india
                #27
                plz check
                • SilverOxide
                  • May 2023
                  • Philippines
                  #28
                  Originally posted by satheesh123
                  plz check
                  Thank you so much kind sir
                  • gog0_81
                    • Mar 2019
                    • Philippines
                    #29
                    thanks
                    • M4n0l0307
                      • Nov 2020
                      • 171
                      • Republica Checa
                      #30
                      Thanks Friend !
                      • lakshitarpitccc
                        • May 2021
                        • india
                        #31
                        thankx
                        • Cerberuska
                          Mobo MSI B550-A PRO password popup
                          by Cerberuska
                          Hello guys,
                          I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                          BIOS I updated to last one.
                          any suggestions?
                          And same thing for two different 5600G, and yes, MoBo supposed to support it.
                          Thank you...
                          11-10-2024, 01:23 PM
                        • mrsith
                          Dell G3 17 3779 - no display after mobo replacement
                          by mrsith
                          Hi guys,
                          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                          04-30-2023, 05:11 AM
                        • Ibod
                          Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                          by Ibod
                          HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                          With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                          Not sure where to go from here ?
                          Is the PSU at fault or is the mobo causing the problem
                          Look forward to any help :-)
                          If I plug the 24...
                          02-08-2023, 11:00 AM
                        • Felipe_Serra_83
                          Dell Inspiron 14-5448 - fan turns off and mobo keeps running
                          by Felipe_Serra_83
                          Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
                          So I got this Dell Inspiron to play with.
                          No charger, so I connected to my bench PSU.
                          The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
                          ------What it did (and didn't do)------
                          1) I turned it on and it powered on. Powered down in 2 seconds by itself.
                          2) Removed RAM, changed slot. Same...
                          04-04-2024, 12:39 PM
                        • tartuf
                          FSP-350GLN(80) not booting mobo properly
                          by tartuf
                          Greetings
                          My old 350W FSP-350GLN(80) PSU was working fine with my current computer for few years(and previously with few other computers as well). Nothing has changed in setup but since last few months I am getting problems while trying to boot PC.
                          What happens, is that PSU starts and I can hear fans, both PSU, CPU, MOBO and GPU. I can also hear HDD scratching and normal starting sounds. But DVI monitor claims that there is "no signal". Moreover, neither USB mouse nor PS2 keyboard does flash leds like it should do upon boot.
                          I have to turn PSU switch...
                          12-23-2022, 10:54 AM
