Looking for HP schematic or boardview 17817-2
  • brew99
    • Jan 2019
    • 132
    HP 14-BA018CA
    Bucks U42 DIS
    17817-2
    448.0BZ10.0021
    or something similar
  • anshad
    • Nov 2010
    • 249
    Re: Looking for HP schematic or boardview 17817-2
    As of today, unavailable.
    • Antonynl
      • Apr 2021
      • 74
      • Nederland
      Still unavailable???
      • anshad
        • Nov 2010
        • 249
        As of today, only BIOS seems to be available even on paid sites. HP schematics rarely leaks to public internet nowadays.
        • Manggolo
          • Aug 2018
          • 3
          • Indonesia
          need foto board .
          Pu5001 burn . need ic code off PU5001
          • natki
            • Nov 2020
            • Israel
            Originally posted by Manggolo
            need foto board .
            need foto board .
            • Roshni16
              • May 2020
              • India
              Still not available
              • daviosw
                • Mar 2014
                • 9
                • ecuador
                CSD59930Q4M thats the IC that you need
                • kingkong computers
                  • Sep 2018
                  • 210
                  • pakistan
                  need foto board .
                  HP 14-BA018CA
                  Bucks U42 DIS
                  17817-2
                  ic number is 59930m
                  • erickirchey
                    Prem Supporter
                    • Aug 2022
                    • 24
                    I'm guessing schematic and boardview still unavailable any one have a 17817-2 that can help identify chip PU4502 Markings BACAQ1
                      • 21861
                      BAC*** SY8288CRAC https://www.badcaps.net/forum/troubl...02#post1538202
                      • PacoGT
                        HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                        by PacoGT
                        hello firends
                        i search the schematic or boardview
                        I have this motherboard, but I can't find the schematic or the boardview.
                        The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                        So the computer doesn't turn on, and the 3V disappears after a few seconds.
                        The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                        The new problem arose after removing the bad chip.
                        3V and 5V remained together,...
                        08-19-2025, 08:25 PM
                      • hosain0489
                        Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                        by hosain0489
                        I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                        Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                        If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                        Thank you very much in advance!
                        07-15-2025, 11:20 AM
                      • re-atari
                        Gigabyte GA-H110-D3A schematic/boardview needed
                        by re-atari
                        Hello all,
                        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                        02-24-2025, 06:45 PM
                      • jonyhdtv
                        HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                        by jonyhdtv
                        Looking for schematic and boardview
                        Model: HP ProBook X360 11 G3 EE
                        Serial: SCG9114JG7
                        Motherboard: L43774-601
                        defect: touchscreen doesn't work (touch works on another computer)
                        thanks to all​
                        01-29-2025, 08:16 AM
                      • jonyhdtv
                        HP ProBook X360 11 G5 ee schematic and boardview thanks
                        by jonyhdtv
                        HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
                        Model: HP ProBook X360 11 G5 EE
                        Serial: SCG0164QLH
                        Motherboard: L83950-601
                        defect: no POWER
                        thanks to all​
                        01-29-2025, 08:11 AM
