Need:lenovo t410s boardview
  • Siddig
    • Jun 2017
    • 264
    • Sudan
    HI
    I have problem( critcal low fix battery error 190)
    I need to BOARDVIEW FOR LENOVO T410S.
  • Siddig
    • Jun 2017
    • 264
    • Sudan
    Re: Need:lenovo t410s boardview
    No boardview for this model,,??.
      • 21917
      Your problem is more likely to be a bad battery,check the lenovo battery recall see if you can get a free battery .https://www.badcaps.net/forum/showth...battery+recall
      • Siddig
        • Jun 2017
        • 264
        • Sudan
        Thanks for replay
        But this power charging issue becoz Its showing that message with out insert battery .
        I need for boardview for fix it.
          • 21917
          Schematic, no boardview sorry https://drive.google.com/drive/folde...HsCe2aqVnOUT3M
          Try flashing bios .
          • Siddig
            • Jun 2017
            • 264
            • Sudan
            Try flashing bios .
            Thanks I have flashing bios but its same problem.
            • on/off
              • Oct 2016
              • 333
              • Indonesia
              Why you didn't mention the mobo's code? For reason more easy to find. There's lot members of forum have store the boardview or schematic by code of motherboard, not by brand your laptop. <<<<<More details your describe it then more easy you got helps>>>>>
              • Siddig
                • Jun 2017
                • 264
                • Sudan
                Board details:
                SHINAI-2 MB
                09247-3
                48.4FY01.031
                • Siddig
                  • Jun 2017
                  • 264
                  • Sudan
                  Shinai-2 mb
                  09247-3
                  48.4fy01.031
                  • Siddig
                    • Jun 2017
                    • 264
                    • Sudan
                    Shinai-2 mb
                    09247-3
                    48.4fy01.031
                    • on/off
                      • Oct 2016
                      • 333
                      • Indonesia
                      Hope helps you:
                      • Siddig
                        • Jun 2017
                        • 264
                        • Sudan
                        Hope helps you:
                        thank you very much dear
                        • Siddig
                          • Jun 2017
                          • 264
                          • Sudan
                          Hope helps you:
                          its dosent open with openBoardview program
                          • anshad
                            • Nov 2010
                            • 249
                            BRD files have many variations. They are not compatible with each other. Below link may help you.
                            http://laptopserviz.bg/enview/bvsoft/
                            • on/off
                              • Oct 2016
                              • 333
                              • Indonesia
                              Couple time I mentioned in several threads, if you just concern with your problems, then you failed to sense other people problems and failed getting learn from other experiences.
                              Also I will NOT give you the files if I can NOT open it!
                              Post #1 the correct one
                              Open Boardview with:
                              Try extract with 7zip.
                              The board view opened with:
                              • Siddig
                                • Jun 2017
                                • 264
                                • Sudan
                                Thank you brother . Now it's open coz I have Changed my Boardview program.
                                Thank you again
                                • Siddig
                                  • Jun 2017
                                  • 264
                                  • Sudan
                                  Thank you
                                  • deepak47
                                    • Jul 2017
                                    • 13
                                    • India
                                    need BORADVIEW + SCHEMATICS
                                    LSN-2 HYB MB
                                    09907-2
                                    48.4FY04.021
                                    If anyone have please help me.
                                    • NConstantinou
                                      LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                                      by NConstantinou
                                      Dear all,
                                      i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                                      the laptop DOES NOT POWER ON..
                                      with it old battery it does power on.
                                      i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                                      when i shutdown the laptop does not power on.
                                      does anyone have any solution!
                                      when is not power on the usb c voltage tester shows 5v 1.3A
                                      when i disconnect battery and power on and then connect battery the tester...
                                      12-10-2024, 04:52 AM
                                    • GabrielS24
                                      Lenovo E540 battery problem
                                      by GabrielS24
                                      Hello! I'm here to look for solutions to reset the EEPROM memory of a Lenovo E540 battery of 62Wh and 540mAh. I even bought a new one on the market (aftermarket BTIBM30) because I couldn't find an original one but it doesn't work. The laptop sees the percentage but blocks the battery charging probably because of the Chinese BMS. In the bios I don't have an option for the battery and I didn't find an older version (v1.57). I replaced the Lenovo BMS with Chinese cells but in windows it doesn't read the battery percentage and says it needs to be changed. I have 12v between D and the red wire....
                                      04-16-2025, 05:23 AM
                                    • code share
                                      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                      by code share
                                      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                      Here's what I've tried so far:
                                      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                      • Booted successfully on AC power only with the battery disconnected
                                      • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                      • Battery
                                      04-21-2025, 12:50 PM
                                    • NConstantinou
                                      LENOVO GYG41/GYG51 NM-D131 REV:1.0 BATTERY PROBLEM
                                      by NConstantinou
                                      Dear all
                                      i have the above laptop which had problem with charging and was repaired. the laptop battery need to be replace also and i did but laptop did not power on with new battery.
                                      installing old battery back, power comes on.
                                      i noticed on battery connector instead of 3.3v on pins 3 and 4, i get 2.9-3.3v and is flactuating.
                                      can someone help!!!
                                      11-26-2024, 06:08 AM
                                    • mrkmpn
                                      Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                                      by mrkmpn
                                      Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                                      This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                                      03-13-2024, 01:54 PM
