DV5-1007ef ightning icon flash 3 times
  • moateez
    • Jun 2014
    • 119
    • algeria
    Hello Friends
    Motherboard :foxconn ml 94v-0 / DAOQt8mb6FO
    Please Ineed Shematics and Bios Fil For This Laptop
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: DV5-1007ef ightning icon flash 3 times
    Those are 0 not O. Search Quanta QT8.
    • moateez
      • Jun 2014
      • 119
      • algeria
      ah thnks friend
      i have found it this is the file
      can you help me to detect the ptobleme
      • moateez
        • Jun 2014
        • 119
        • algeria
        after checking and compare with schematics
        all power voltage is good 3.3 - 5 - 19
        3.3 on bios ic but laptop dont power On
        • moateez
          • Jun 2014
          • 119
          • algeria
          I need help please
          • moateez
            • Jun 2014
            • 119
            • algeria
            Plese BIOS file to try
              • 20837
              Post your bios backup . EDIT: 3 falshes is usually a memory fault,try reseating the memory or try different ones.
              • moateez
                • Jun 2014
                • 119
                • algeria
                OK sir i will pos it thnx
                  • 20837
                  • moateez
                    • Jun 2014
                    • 119
                    • algeria
                    This IS the original Fil Remove from This Laptop
                    • adiserwis
                      • Nov 2013
                      • 14
                      If I understand correctly from the title it is lightning icon flashing (DC port LED)? That usually means the power supply or motherboard is having a problem
                      • moateez
                        • Jun 2014
                        • 119
                        • algeria
                        need help please
                          • 20837
                          Heres 2 bios to try.
                          • moateez
                            • Jun 2014
                            • 119
                            • algeria
                            thnks brother iwill try and tell you
                            • moateez
                              • Jun 2014
                              • 119
                              • algeria
                              same probleme after try 2 bios
                              • moateez
                                • Jun 2014
                                • 119
                                • algeria
                                Cant found the problème
                                • moateez
                                  • Jun 2014
                                  • 119
                                  • algeria
                                  i still with this lap
                                  ***RSMRST is worck 3.3 SLP S3 SLP S5 are ok
                                  plase help
                                  • moateez
                                    • Jun 2014
                                    • 119
                                    • algeria
                                    Friends need help
                                    • edugimeno
                                      Bl in Samsung will flash a couple times, then shut off
                                      by edugimeno
                                      Hi there!
                                      I have this Samsung LE32A336 TV that when you turn it on, it works fine for a second, then backlight flashes off/on for 3 or 4 times, and then definitely off until you turn the TV off again
                                      I guess the BL driver is "trying" to keep it up and sees either lower or higher current flowing to the led strips, but just to be safe, is there any way to identify if the problem is in the led strips (open or shorted LEDS) or in the BL driver IC before opening the front side?
                                      Thanks a ton!
                                      12-06-2022, 11:25 AM
                                    • abajor
                                      Canon VIXIA HF S10 A read data from inernal flash memory.
                                      by abajor
                                      Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                      Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                      The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                      I think my best shot is to figure out a way to read the internal flash memory outside...
                                      07-20-2024, 12:04 AM
                                    • Ihandyrepair
                                      4 red flash led 65X950G boot Sony and android logo but then black
                                      by Ihandyrepair
                                      HI guys
                                      I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                      here is the issue
                                      I have Sony and android logo. but then 4 led red flash lights front of the tv
                                      I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                      but then I get black screen and 4 red flash light at the front LED
                                      but I get 3 led flash on the LED driver board.
                                      I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                      so I tried...
                                      07-11-2024, 01:45 AM
                                    • abhorsen
                                      Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                      by abhorsen
                                      Hey guys,
                                      Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                      Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                      Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                      07-06-2023, 10:22 AM
                                    • ekozeko333
                                      [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                      by ekozeko333
                                      I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                      🔥 The Problem Started After Suspected ESD/PD Fault
                                      I experienced a power issue or ESD event through a USB-C charger
                                      After that, the NX20P5090 power switch was visibly burned and was replaced
                                      Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                      🧠 What I’ve Done So Far
                                      Flashed...
                                      06-21-2025, 02:48 AM
