E5-573 da0zrtmb6d0 need brd files and audio problem
+ More Options
Posts
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Hi i have this laptop fully working but with problem in audio.
    In headphout out all is working , with internal speaker i have very low audio , and sometimes the windows audio bar its freeze .
    Any suggestion ??
    i'm also searching for brd to check resiston and caps
  • Sergio Kub
    • Jul 2018
    • 169
    • Brasil
    Re: E5-573 da0zrtmb6d0 need brd files and audio problem
    Can anyone provide me the Board view of this board.
      • 21032
      schematic https://www.badcaps.net/forum/attach...3&d=1573895260
        • 21032
        PDF Boardview
        • Sergio Kub
          • Jul 2018
          • 169
          • Brasil
          Thank you very much
          I searched a lot for a doc that could help me with this notebook and I couldn't find
          • nabilgo
            • May 2016
            • 303
            • L.A
            Originally posted by SMDFlea
            PDF Boardview
            thank you so much bro
            • joaquinmjuan
              • Sep 2014
              • 31
              • España
              thank you
              • kostukas1985
                • 15
                • lithuania
                Normal Boardview
                • allantech
                  • Aug 2021
                  • 7
                  • phillipines
                  has anyone have this boarview will help me alot thank you (DA0ZRTMB6D0 REV)
                  • aekie
                    • May 2017
                    • 8
                    • thailand
                    Normal Boardview
                    thank you
                    • samson7point1@yahoo.com
                      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                      by samson7point1@yahoo.com
                      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                      The player processes the audio signal using two different reference frequencies. The "R"...
                      04-30-2024, 11:22 AM
                    • falcontech
                      MOTU TRAVELER MK3 AUDIO PROBLEM
                      by falcontech
                      Good Afternoon
                      I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
                      01-24-2025, 08:47 AM
                    • Gibon378
                      Problem with stopping audio and video for no reason
                      by Gibon378
                      PC Specs:
                      • CPU: Ryzen 5 1600
                      • GPU: GTX 1080 Palit JetStream
                      • MOBO: ASRock ab350 PRO4
                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                      • PSU: XFX 650W (don't remember what model)
                      • OS SSD: ADATA SP920
                      • OS: Windows 10 21H2
                      Problem description:
                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                      11-19-2022, 09:41 AM
                    • tk5ep
                      Stanmore JN3018 audio problem help request
                      by tk5ep
                      I've been given a non working Stanmore JN3018 loudspeaker.
                      The power supply part works normally, I have all voltages on all chips. But no sound is coming out.
                      I tried to track the audio signal from the inputs to the loudspeaker.
                      Unfortunately, it's not easy, as most signals are PWM. But the analog part is working, and I can track the PWM at the inputs of the TAS5508c.
                      At the TAS5508c output, I only have pulses which I can find on the input of the final amplifier TAS5342a.
                      Can somebody help me to resolve this problem ?
                      02-16-2025, 10:46 AM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
