Need A1708--820-00840-01 schematic with boardview
  • Rashid36
    • Aug 2014
    • 64
    • Saudi Arabia
    Please Help me out
    Need schematic with boardview
    for A1708 EMC 3164
  • chris-swe
    • May 2018
    • 14
    • Sweden
    Re: Need A1708--820-00840-01 schematic with boardview
    Did you get it?
    Im looking for the same.
    • MobileXT
      • Oct 2012
      • 214
      Did you get it? I also need one.
      • Mojotechie
        • Oct 2018
        • 5
        • usa
        Did you guys get ahold of that BRD??
        can you share?? Thanks in advance
        • heta1000
          • Jul 2013
          • 34
          • egypt
          hi thanks ...i need 820-00840-01 this is not exactly the same i think it's 820-00875
          • Dodge101
            • Sep 2018
            • 8
            Be warned, what has been provided is not 820-00840 but in fact 820-00875
            • Sergioz
              • Apr 2016
              • 12
              • New Zealand
              What a strange subtle difference between two 2016 and 2017 models, huh. I realized they're so different when failed to found two elements on the schematics I've got 8-) Thanks, mate!
              • piernov
                • Jan 2016
                • 4439
                • France
                Yes, only the 2016 820-00875 schematics/boardview are available, not the 2017 820-00840. The 2017 at least has an additional chip PI3USB32224BXEAE near USB-C ports that can sometimes fail.
                • commtech
                  • Aug 2021
                  • usa
                  Originally posted by IMLJ
                  Here it is. I have downloaded a lot stuff here, now it's time to return...
                  Thank you for the schematic and a board view, unfortunately, I believe it is emc 3154, NOT 3164, please let me know if I am wrong.
                  • applehost
                    • Sep 2021
                    • rep. of .korea
                    Thank Ypu.
                    But, The circuit between the usb-c type connector and the U3900 does not match.
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      This is schematics and boardview for 820-00875 not 820-00840 (not available). PI3USB32224BXEAE is only present on 820-00840 not 820-00875.
                      • Pragmatiko
                        • Jul 2013
                        • 468
                        • IT
                        you are right, i found it short...
                        Thank you very much
                        • Dodge101
                          • Sep 2018
                          • 8
                          I do not get it. Why is everyone saying thanks to something that is wrong???? because the schematic that has been provided is for 820-00875 and NOT the 820-00840.
                          can't the mod's edit the thread title to ammend it?
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            I pointed it out multiple times but people do not read.
                            Moved posts to the existing 00875 thread and deleted the renamed files.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3627
                              • slovakia
                              as u said schem is different but is there BV available for 840?
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                Never seen it outside XinZhiZao.
                                • koby058
                                  • Jan 2017
                                  • 387
                                  • israel
                                  Hi
                                  Any body have schematic with boardview
                                  for A1708 EMC 3164
                                  • PacoGT
                                    HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                                    by PacoGT
                                    hello firends
                                    i search the schematic or boardview
                                    I have this motherboard, but I can't find the schematic or the boardview.
                                    The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                                    So the computer doesn't turn on, and the 3V disappears after a few seconds.
                                    The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                                    The new problem arose after removing the bad chip.
                                    3V and 5V remained together,...
                                    08-19-2025, 08:25 PM
                                  • hosain0489
                                    Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                                    by hosain0489
                                    I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                                    Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                                    If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                                    Thank you very much in advance!
                                    07-15-2025, 11:20 AM
                                  • GfilipeZ
                                    Macbook A1708 / 820-00840-A / Can't find IC on schematic neither boardview
                                    by GfilipeZ
                                    I'm diagnosing a machine that won't turn on.
                                    When I did the visual inspection under the microscope, I detected a blown IC next to the USB-C connectors.
                                    But i can't find this IC on schematic neither boardview.
                                    I send attached pictures of the IC and its location.
                                    Does anyone know if there is another version of Logic Board, which has this IC on schematic and boardview?
                                    Best regards....
                                    02-21-2022, 07:58 AM
                                  • re-atari
                                    Gigabyte GA-H110-D3A schematic/boardview needed
                                    by re-atari
                                    Hello all,
                                    Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                    This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                    02-24-2025, 06:45 PM
                                  • jonyhdtv
                                    HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                                    by jonyhdtv
                                    Looking for schematic and boardview
                                    Model: HP ProBook X360 11 G3 EE
                                    Serial: SCG9114JG7
                                    Motherboard: L43774-601
                                    defect: touchscreen doesn't work (touch works on another computer)
                                    thanks to all​
                                    01-29-2025, 08:16 AM
