Re: Need data scheet I/O KB9022Q D (ENE)
I'm trying to do the same. Have you managed to create the config file?
hi anybody know which is the compatible IO suitable with kb9022?Leave a comment:
thank you for kb9022q datasheet.Leave a comment:
Would anyone have a register description for the EC in I/O KB9022Q D? Or have any info about which registers are involved in controlling the fan speed? I'm trying to make a configuration file for notebook fan control...Leave a comment:
Yes I tried same as kb9012 but can't read and write successfullyLeave a comment:
Datasheet not available. Pinout should be same as 9012 though i'm not 100% sure. Anyway having difficulties in read/write kb9022 with RT809F as well as svod.Leave a comment:
HI please i need data scheet or Pin out super I/O KB9022Q D (ENE)Tags: None
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by welcometooHi brothers, please i need help diagnose acer nitro 5 no display issue.
model: nitro 5 an515-55
motherboard part number: GH51M LA-K862P Rev: 1A
i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
i flashed new bios also ec(ene kb9022) the same result .
disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...4 Photos -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by kingiiiHello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not...
by vbogoevHello,
Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
Code:[PWRAP] pwrap_init_preloader [PWRAP] pwrap_init [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5 [PMIC_WRAP]wrap_init pass,the return
- Loading...
