Need data scheet I/O KB9022Q D (ENE)
  • wengski
    • Mar 2022
    • philippines
    Re: Need data scheet I/O KB9022Q D (ENE)
    Thanks a lot!
    • Zireael
      • May 2022
      • Turkey
      Thanksss very much for datasheet. Were anyone be able to solve how to control fan?
      • PradipKaka
        • May 2022
        • Nepal
        Originally posted by luckyfahad79
        Kb9022Q D error at Blank check with SVOD anybody has done it yet ?
        Blank Check False
        I am having the same issue and re-flashed bios shown $$$$$ in every bios, after flash
        • wws911
          • Apr 2020
          • 10
          • South Africa
          Originally posted by lzeta
          Thank you, do you know witch pins I must use to program it with a CH341A?
          Hey im also looking for this infom
          I have the same issue .: if you get a solution please let me know aswell
          • rxyzm
            • Apr 2016
            • 64
            • India
            Originally posted by zolomen
            đây
            Thank You.
            • Xruss
              • Dec 2020
              • 9
              • Казахстан
              #26
              Thank you
              • Ghost18_07
                Zakaria
                • Mar 2018
                • 73
                • Algeria
                #27
                Thanks bro
                • Jamescl
                  • Feb 2017
                  • 28
                  • Bangladesh
                  #28
                  thanks
                  • samuelphirik
                    • Oct 2021
                    • 13
                    • Zambia
                    #29
                    Thank you so much
                    • WTFRules!
                      • Feb 2023
                      • 23
                      • Argentina
                      #30
                      I´m looking for info to flash the KB9022Q D with CH341A and NEOPROGRAMMER like it ´s a KB9022, but as I still don´t have either of both parts for test before asking, I couldn´t find any info if this is possible with such programmer for the KB9022Q D version of EC IC.
                      If anyone can confirm or deny this, would be awesome.
                      Thanks!
                      • WTFRules!
                        • Feb 2023
                        • 23
                        • Argentina
                        #31
                        Thanks!
                        OK, I can confirm that with CH341B and NeoProgrammer (MAlware aside) the KB9022Q D is 100% programmable.
                        Hope this helps to anyone looking the same as I did.
                        Have a good one.
                        • forall
                          • Jul 2016
                          • 6
                          • spain
                          #32
                          Have a good one.
                          hi
                          Can you give any information about to do that?
                          thanks
                          • forall
                            • Jul 2016
                            • 6
                            • spain
                            #33
                            hi
                            i'm looking for any information about to programm kb9022q with RT809H.
                            any help is wellcome.
                            thanks
                            • WTFRules!
                              • Feb 2023
                              • 23
                              • Argentina
                              #34
                              Originally posted by forall
                              hi
                              thanks
                              In the NeoProgrammer software there are pinouts about how to connect it to the CH341A and pinout of the IC itself.
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • vbogoev
                                Lenovo S6000 won't turn on. Data recovery needed.
                                by vbogoev
                                Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                                Code:
                                [PWRAP] pwrap_init_preloader
                                [PWRAP] pwrap_init
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                                [PMIC_WRAP]wrap_init pass,the return
                                06-20-2023, 06:36 AM
                              • mscottdoran@gmail.com
                                Can anyone identify the classification of this data signal?
                                by mscottdoran@gmail.com
                                Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                                The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                                The boards are powered by a ground referenced...
                                02-08-2025, 11:31 AM
                              • Joe24
                                Maytag Whirlpool Kenmore clothes dryer data bus
                                by Joe24
                                Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                I've been over the board looking for...
                                01-13-2025, 06:50 PM
                              • DoOm86
                                Swap nand flash smartphone for data recovery
                                by DoOm86
                                Hello everyone.
                                I would like to know more about the following topic:
                                Nand flash on smartphone for data recovery.
                                I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                                But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                                How does it works? How do I know if data are encrypted or where is the key?
                                I know there are also very expensive external socket where you can put the nand flash in...
                                08-20-2023, 07:10 AM
