How to read and understand schematic diagram.
    Good morning engineers, I'm new to laptop motherboard repairs, I want to be good at what I do and will like to learn how to read and understand laptop schematic diagram.
    Any link to videos, books or direct teaching will be appreciated. Thanks
    Re: How to read and understand schematic diagram.
    Search google and youtube many have.
      It is not really possible to directly learn to read electronic schematics. It is necessary to first understand basic electronics, then progressing to understanding how various electronics components function and interact.
      And also to understand how logic functions are electronically represented. Maybe you do already?
        I have done that, I have some videos but most of them are demos.
          I know the basic electronics and their functions like diode, lead, capacitor, coil, mosfet etc.
          Concerning how they interact and how they are electronically represented is what i don't understand too, I don't know if I can learn that together with reading schematic.
            Schematic is actually only graphic representation of component interconnection,you must really know how it works first...in schematic you only see how are this components together connected,nothing more..
              Thanks for your contribution, I know the basic components and their functions, the interconnection or how they interact is what I don't get, pls can you explain better?
                i found this . http://www.electronics-tutorials.ws/ i looks like good point to start with electronic and schematics..
                  Try understand the power in/charger circuit first! Search for the datasheet of the charger ic type! Read the datasheet, and understand how the sample circuit works. Search for how switching power supply works! That would be great basic knowledge for reapir.
                    In my experience about understanding a laptop schematic the core that you need to understand is the electronic array of components, like voltage divider with resistors and what funtion do in a motherboard. step down converters with a PWM and power mosfets in synchronous configuration. Understand that an IC is like other PC inside the motherboard that made an specific funtion and learn how to test it. Understand that some IC power up with an enable signal and learn to trace it back generally to the EC KBC and so on.
                      Thanks, I really appreciate. I'll definitely check it out.
                        Thanks, I appreciate.
                          Great, I'll read about the voltage divider and also understand component codes and abbreviations.
                          Thanks.
                            Will check this. Thanks for the information.
