Lenovo Yoga 2 Pro Lenovo nm-a074 schematic and boardview
  • spintop
    • Feb 2011
    • 132
    Need the schematic of the laptop.
    Got a dead laptop.
    Thank you in advance
  • tomodachi
    • Apr 2012
    • 612
    • Turkey
    Re: Lenovo Yoga 2 Pro schematic and boardview
    Hi, some information please ? sympthoms etc.
    • spintop
      • Feb 2011
      • 132
      Cannot on, blank screen, keyboard backlight flash every few second.
      • spintop
        • Feb 2011
        • 132
        anyone can help ?
        • Drassh
          • Apr 2017
          • 43
          • Mexico
          Have you dissembled it yet? What are the etchings on the board to better identify and search for it...
          • spintop
            • Feb 2011
            • 132
            yes dissembled. main board is small with cpu n ram embedded.
            part number VIUU3 NM-A074 rev1.0
            ebay is selling but expensive.
            anyone got it, thanks
            • nico235
              • May 2017
              Hi, I got the same laptop, and it doesn't start...Have you repaired yours?
              • spintop
                • Feb 2011
                • 132
                I have not repaired it yet.
                No idea what is wrong.
                • snsent
                  • Nov 2010
                  • 103
                  • Malaysia
                  Try this bios..
                  https://www.badcaps.net/forum/showthread.php?p=1033593
                  Last edited by SMDFlea; 03-23-2021, 04:47 AM. Reason: Bios moved to "Bios Requests ONLY!"
                  • 580shahzad
                    • Jan 2012
                    • 64
                    • PAKISTAN
                    • spintop
                      • Feb 2011
                      • 132
                      580s thanks for the file. its a great help looking into the motherboard.
                      wonder if u also have the boardview file
                      • meritosari
                        • Oct 2010
                        • 774
                        • Indonesia
                        I think right now not available, Hard to find boardview for LCFC-NM family.
                        • spintop
                          • Feb 2011
                          • 132
                          With ac adaptor n battery connected, I am only getting 8v at Vin (see diagram
                          Page 29). I m expecting 19v here. This is not normal isn't it ?
                          Btw I have already change the IC pu10.
                          Dcin at Pin 2 = 19v
                          Adet pin 3 = 3.5v
                          Acok pin 14 = 3.3v
                          Vdd pin 19 = 5.1v
                          Above voltage looks normal. Ie without switching on the laptop yet.
                          I also have 3.3v available. So pu6 is working.
                          But no 5v from pu5. Meaning system is not turn on yet.
                          At v_chg is 19v.
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            what is the voltage on pin 4 of pq4 and pq33?
                            • spintop
                              • Feb 2011
                              • 132
                              at PQ4 -- pin4 =1.8v pin1=20.2v pin5=20.2
                              at PQ33 -- pin4 = 19.7v pin1=19.7v pin5=20.2
                              • spintop
                                • Feb 2011
                                • 132
                                can Vin be just 8.5V when ac adaptor and batt is present ?
                                • atsio
                                  • Oct 2013
                                  • 819
                                  • Greece
                                  Make all measurements without battery. Remove pq33 and check it.
                                  • spintop
                                    • Feb 2011
                                    • 132
                                    with PQ33 removed, no batt. getting below readings
                                    at PQ4 -- pin4 =1.8v; pin1=20.2v; pin5=20.2
                                    at PQ33 -- pin4 = 1.2v pin1=1.1v; pin5=20.2
                                    at pu10, pin26 (sgate) =1.3v
                                    i checked pq33 (p-channel), in diode mode drain-source is 0.545
                                    pq33 seems normal.
                                    • spintop
                                      • Feb 2011
                                      • 132
                                      I am not able to fix the laptop. I have already sold it away. Are u getting Vin abt 8.5v ? My initial thought was 19v, but I think 8.5v should be normal for this laptop. Then the power ic is fine.
                                      I saw someone online heating up the CPU area, and it solved the blinking keyboard issue. So it could jus be some weak solder joints.
                                      • flankerzo
                                        • Sep 2018
                                        • 7
                                        • Nitra
                                        hmm, sorry to hear that, yes i have 8,5 V Vin, mosfets looks okay, i tried reflowing cpu, but nothing, only that one chip is heating like hell. I accidentaly touch some resistors near it and one fan turned on
                                        im wondering, can i swap cpu to normal yoga 2 13? i know its soldered on i have usable equipment, in my yoga 2 13 is i5 4210u 3MB cache and only 4gb ram :/
                                        or LCD screen ? it have different cables, but eDP should be same on lcd pannel, swap 4k to yoga 2 with 1080p sreen
                                        i will wait for IC from ebay, Now i am only looking for what can be done.
