820-00138-a A1398
  • ACS-Repair
    • Feb 2021
    • 204
    Re: 820-00138-a A1398
    Has anyone been able to locate a proper Boardview layout for the 820-00138? Most sites are still calling their layout correct, but it is just an 820-3662. I'm happy to pay for it if it is correct.
    • piernov
      • Jan 2016
      • 4439
      • France
      For most circuits, 820-00163 or 820-3662 should help.
      I've only seen the correct one in XinZhiZao.
      • ACS-Repair
        • Feb 2021
        • 204
        Thanks piernov. I'll give it a try. Much appreciated!
        • pacwcbs
          • Nov 2015
          • 28
          • Dominican Republic
          • shayanabo
            • Jun 2019
            • usa
            I have high fan speed but can't really seem to find any other issues with the machine, mayyyybe slightly laggy?? but when I run diagnostics I get an you have an SMC Issue PFM008 and Camera NDC001 but the camera works fine as well.
            The Mac has been water damaged
            Any Help on where to start or what to replace would be greatly appreciated
            • jeorgeconcepcion
              • Mar 2022
              • Philippines
              #26
              hi everyone, does anyone already have boardview and schematic for 820-00138-A A1398?
              can you please share with me...
              Thanks in advance!
              • vgcrepairs
                • Apr 2020
                • 5
                the boardview posted and the actual board are not even close to same
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  #28
                  https://www.badcaps.net/forum/showpo...8&postcount=16
                  https://www.badcaps.net/forum/showpo...2&postcount=22
                  • jayannjeps
                    • Oct 2020
                    • india
                    #29
                    Originally posted by freakazorzz
                    I'm working on a 820-00138-A board that was liquid damaged.
                    It's booting but goes into panic-mode (loud fans) and the cpu and ram is getting very hot.
                    I have 19,6V on PPBUS_G3H, this is too much, it should be 12v.
                    Does anyone has any idea what I can do next?
                    Thank you
                    you can replce the ic in such case.
                    • jayannjeps
                      • Oct 2020
                      • india
                      #30
                      you may check the resistor value according schematic.. there must be an faulty resistor.
                      • nelciguria
                        • Sep 2018
                        • sao paulo
                        #31
                        obrigado!!!
                        • JTEK
                          • Feb 2018
                          • 49
                          • Philippines
                          #32
                          thanks
                          • huhong1213
                            • Jan 2024
                            • 中国
                            #33
                            苹果MacBook Pro Retina 15“ A1398 820-00138 051-00330原理图和板视图
                            https://www.badcaps.net/forum/docume...tic-board-view
                            • telfix
                              • Jun 2020
                              • 7
                              • Poland
                              #34
                              I have a problem editing the file. Please help me edit to my serial number DGKGM0H0DHJW.​
                                • 21889
                                Post your request in the "Bios requests ONLY!" sub forum.
                                • silver60618
                                  How to clean Liquid Metal from under CPU?
                                  by silver60618
                                  Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                                  The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                                  Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                                  07-11-2025, 01:47 PM
                                • Hondaman
                                  Liquid cooling?
                                  by Hondaman
                                  I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                                  (After previous generation hardware [Gigabyte] didn't...
                                  05-08-2025, 09:37 PM
                                • kurland
                                  Strange liquid on damaged GTX1080 card
                                  by kurland
                                  I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
                                  As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
                                  Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
                                  11-17-2020, 07:14 PM
                                • Fam787
                                  HELP! A1398 Dead,
                                  by Fam787
                                  I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
                                  Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
                                  12-27-2024, 05:19 PM
                                • mitchw
                                  MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                                  by mitchw
                                  Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                                  It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                                  I quickly took it apart and washed the liquid residue off the mainboard.
                                  The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                                  The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                                  Now the laptop...
                                  07-16-2025, 07:55 AM
